1,200 mile 18 gt engine noise
Czs550
Cleveland Ohio
Connor
2018 10r80 GT, Lightning Blue
Have a tick noise that sounds like the bbq tick. Noise starts to occur after about a minute of running, what do you guys think?
[ame]https://vimeo.com/276045667[/ame]
[ame]https://vimeo.com/276045737[/ame]
[ame]https://vimeo.com/276045696[/ame]
Brian V
USA Retired
Native Earthling
2015ecoboost premium 201A Nav Sec Race Red
BaD GAS PLUGS who the F knows .... go get on it dawg yer carboned up ....
grabber yote
Corn Fed
Goldsboro, North Carolina
Grabber Blue 2017 GT PP
Change the oil and also check to see if you have any pending misfire codes. A couple times it sounded like rod knock but if that was the case it would be a constant steady noise. Direct injection motors run really dirty and push fuel into the oil. I'm thinking changing the oil will help.
bootlegger
Enginerd
Mount Pleasant, SC
James
Ex 2008 Mustang GT Owner
Dual fuel engines shouldn't build up carbon any quicker than PFI. Gas in oil would be oil dilution, and easily found via oil analysis. It is very unlikely someone would see oil dilution after only 1200 miles. The tick seems to be one of the more common issues in these new engines, and may or may not be leading to a mechanical failure.
Czs550
Czs550
Cleveland Ohio
Connor
Mine is exactly the same way. Does it on cold starts then goes away after a few minutes.
Same here its just annoying, spend 40k on a vehicle and this happens.. just unacceptable
4 ROUSH
NONE
COMMUNITY
SOLD
I have it as well. I had a 17 GT with the prior generation 5.0. This new noise was not present on that power plant. Its still currently on original factory oil. Just scheduled my first oil change at the dealership. My GT has slightly over 600 miles now.
BLU2DSKY
Toronto
2018 GT, 2005 V6
Does that mean all cars with a tick have to be checked out?
4 ROUSH
NONE
COMMUNITY
SOLD
I just want to chime in on this, from a non technical perspective. If there are no CEL codes , no WRENCH, no loss of power etc .Decide as the individual owner if a dealership visit is needed. I have decided for myself not to have it checked. If it needs the tow & is still under WARRANTY, for sure off to the dealer. I have owned seven Mustangs over the years . Two S197 supercharged & modified extensively. ***I am not stating that it is not an issue by no means.*** Then again with this new direct injection design, it just might be how Ford engineering designed this power plant. New cars on the dealerships lots have this noise,including late 2018 production cars .I have also heard this noise on the F150 as well.Just my 2 cents.
ponyv6
ozzy
2019 301A PP1 Velocity Blue
I have the same exact sound. It doesnt do it always at idle. I can replicate most of the time at 1500rpm with very low throttle.
[ame]
dont wanna flood the topic with other videos. you can see other videos here.
https://www.youtube.com/channel/UCn4W8Dhr70qdFVknfSHvAYA?view_as=subscriber
I left it to the dealer for 10days, they just waited to hear back from ford. I was impatient and picked the car back. not planning to drop it again till they figure it out.
like every body says, there is no performance issue.
mine started after the first oil change at 1200miles. I might do early oil change at 2000miles to see if it is gonna change anything.
bootlegger
Enginerd
Mount Pleasant, SC
James
No, not really. There is some mild correlation between the noise and a few mechanical failures, but we don’t have solid causation yet.
