Supercharger belt science & the gates new RPM belt...
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Been reading alot about supercharger belts ever since i got my new ProCharger D1x. I upgraded the belt that comes with my kit to a Gates Hd green belt and I'm happy with its performance. Then i read about their new rpm belt and i ordered one yesterday here is the info that convinced me to get one:
Rpm belts are a new belt designed for superchargers. Here is a direct quote from gates.
RPM (Racing, Performance, Muscle) is a new, no compromise belt built specifically for supercharged applications.
Whereas 99% of all belts on the market today use a polyester tensile cord, the RPM series uses an aramid tensile cord. This is the same fiber found in bulletproof vests and is 10x stronger than steel and 5x less elastic than polyester. When polyester heats up (which it does even from normal use) it will stretch out. As you can imagine, when that belt stretches out you experience belt slip and boost loss. Eventually the elastic properties of the polyester will fail and the belt that was once 100” will stretch to 100.25”, at which point the tensioner can no longer compensate for the stretch and generally results in belt failure.
Due to the strength and minimal elasticity of aramid fiber, the RPM series of belts will not stretch which allows the belt to maintain its true length throughout its service life. This results in more consistent boost and in some instances, users have reported a 1-2psi increase merely from switching from HD belts to RPM belts. We actually have some user submitted under hood video on our Instagram page (GatesRPM) that clearly demonstrates the difference between polyester and aramid corded belts.
Another main benefit of the RPM line is the use of two layers of adhesion gum. These layers create a sandwich around the tensile cords which transfers the load to the strongest part of the belt; the jacket (or smooth backside of the belt). FleetRunner HD belts got a reputation for strength because they use one layer of adhesion gum, standard micro-v belts forgo any adhesion gum.
RPM belts also utilize a patented rubber compound with the highest coefficient of friction available and are built in common OE supercharger sizes as well as many sizes used with aftermarket setups. The RPM line has expanded to 299 part numbers with new numbers being added every quarter.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
I wonder if this increased traction is harder on the head unit? I also heard these belts snap if not tensioned properly.
Dominant1
Dominant1
Dr Frankenstang
I haven’t heard anything about these belts snapping, they haven't been out that long. Dont see how a belt built from this material could snap, but I understand what your implying, something has got to give... only way to know is to buy one and mount it. Mine will be here Wednesday!
dubster99
Nor*Cal
2015 Ingot Silver GT PP
Yes, they are known to snap under normal tensioning...they need to be adjusted differently. There was a thread posted the other day about this from svtp.
2-tone
Cincinnati
15 mustang gt m6
I snapped 4. I believe they are less forgiving than the green. Your alignment and tensioner needs to be exactly right or they won't last long.
keltymd
Murfreesboro
2017 PP
the thing I read was where on most PD blowers you want about 80% on your tensioner with the RPM due to the material and the fact they dont stretch you only want about 20%
Dominant1
Dominant1
Dr Frankenstang
What about centrifical set ups?
dubster99
Nor*Cal
Doesn’t matter what setup it is. A belt is a belt. The rpm belts don’t give like the normal belts. People run them with normal tensionand end up snapping them. I’ll be sticking to normal belts and more belt give.
keltymd
Murfreesboro
2017 PP
So if you dont have a manual adjuster in your setup as well as the auto adjuster I would say if you want RPM you may need to go a bit longer on the belt
racingmason
NC
2017 GT Premium
I have one and my tensioner is nearly maxed. I'd say 80 to 85%. I'm one size smaller than KB recommends for a 3.325. Are you saying i need to go bigger to take some stress off the belt?
keltymd
Murfreesboro
2017 PP
If you are running the RPM belt there was another thread where gates and whipple both said run the tensioner at 20%
cobra99dave
Philadelphia
I have snapped 2 of them on my KB setup. They were tensioned pretty tight probably 80-90%. I went back to regular gates belts and never had a problem since.
keltymd
Murfreesboro
2017 PP
From what gates says that is your problem. They don’t stretch so you don’t want that level of tension on them. The reason for high tension is to account for belt stretch.
