Ford PR: 2015 Mustang, Best Handling Ever, PP Consistently Beat Boss 302 at the Track
Jarstang
Administrator
Staff member
Administrator
M6G
Ford
Agile Ford Mustang Features All-New Suspension; Performance Pack Raises Bar for Handling and Braking
  • 2015 Ford Mustang features new, fully independent front and rear suspension mated with stronger and lighter platform for improved handling and ride quality through better wheel and body control
  • Three new brake systems ensure new Mustang stops as well as it accelerates and turns
  • Available performance packs for Mustang EcoBoost® fastback and convertible and Mustang GT fastback raise the bar for handling and braking performance on both the road and the track
With new fully independent front and rear suspension systems, the all-new sixth-generation Ford Mustang is expected to be the nimblest and most comfortable example of the breed to date. Mustang EcoBoost® and Mustang GT fastback customers can also add an available performance pack for maximum all-around capability, continuing 50 years of Mustang personalization.
“When we began development of the sixth-generation Mustang, we knew we had a challenge ahead of us to beat ever-increasing customer expectations, as well as new competitors in the marketplace,” said Raj Nair, Ford group vice president, Global Product Development. “We added content where it mattered – including an independent rear suspension for better handling and ride, and bigger brakes for better, shorter and more consistent stops. We also doubled the number of airbags.
“Even with all of that extra hardware, smart engineering throughout every component of this car enabled us to achieve a base curb weight of 3,524 pounds for the new Mustang EcoBoost fastback – just six pounds more than the lightest 2014 Mustang V6, and still the best power-to-weight ratio of any car available in the United States for under $50,000.”
Building on a solid foundation
With an all-new platform and fully independent suspension, the 2015 Ford Mustang sets new handling benchmarks for the brand, achieving world-class performance in both dynamics and ride quality.
“In order to develop precise and predictable handling characteristics, a car needs a solid platform where the suspension mounts don’t move relative to one another,” said Tom Barnes, Mustang vehicle engineering manager. “The structure of the new Mustang is much more resistant to twisting, with 28 percent more torsional stiffness for the fastback and a 15 percent improvement for the convertible.”
Despite being so much stronger, this is a very efficient horse, with a body-in-white that is actually lighter than the previous version. This was achieved through extensive use of advanced technologies and materials including hydroforming, laser welding and high-strength steels. Lightweight aluminum is used for the hood and front fenders to help reduce body mass and improve the weight balance.
Attention to detail throughout the design process yielded significant weight savings that helped to offset the increases from adding performance-enhancing features such as larger, more powerful brakes and independent rear suspension. The result is a vehicle that is more capable than before while remaining significantly lighter overall than key competitors.
The structure of the 2015 Mustang is also designed to meet new, more stringent crash safety standards. Some of the other components now made of aluminum include the rear suspension knuckles, rear axle housing on automatic transmission cars, rear control arms and rear brake calipers. Even parts made of steel and other materials such as the hollow rear stabilizer and the new seats have been intelligently designed to meet performance standards while keeping weight down.
“We added a lot of content to the new Mustang in order to hit our performance targets and meet today’s customer expectations,” said Dave Pericak, Mustang chief engineer. “With a base curb weight of 3,524 pounds for Mustang EcoBoost fastback, and increases ranging from six pounds to 87 pounds for V6 and GT fastbacks, Mustang is still substantially lighter than the competition.”
Mustang EcoBoost fastback has best-ever weight distribution for a Mustang, with 52 percent of its weight over the front axle and 48 percent to the rear, while Mustang GT has 53 percent of its mass on the front wheels. In combination with a lineup of new or upgraded powerplants, Mustang improves on its already leading power-to-weight ratios. Mustang EcoBoost carries fewer than 11.36 pounds per horsepower, while Mustang GT has as little as 8.52 pounds per horsepower.
With a stronger yet lighter structure to build on, the hardware was added to meet aggressive performance targets. Every new Mustang features an all-new integral-link independent rear suspension. The suspension architecture is based on a lower control arm, integral link, upper camber link and a toe link. The geometry, springs, dampers and bushings have all been specifically modified and tuned to deliver improved mechanical grip for this high-performance application.
The new suspension geometry of Mustang now generates twice as much anti-squat and anti-lift force for better pitch control to keep the body level under hard acceleration and braking. New aluminum alloy rear knuckles help reduce unsprung mass to enable the tires to follow the road for better ride and handling.
At the front, a new non-isolated perimeter subframe replaces several individual crossmembers to help stiffen the structure while reducing mass, contributing to a better foundation for more predictable wheel control that benefits handling, steering and ride quality.
The new double-ball-joint front MacPherson strut system enables the use of larger, more powerful brakes without resorting to excessive wheel offsets that would hurt steering feel. Like the rear, the front end contributes to improved pitch stability with additional anti-dive in the geometry.
The total system now does a much better job of keeping the four Mustang tires in contact with the road where they can contribute to improved dynamics while making cruising and daily commutes more comfortable.
This is expected to be the best-stopping Mustang yet. Three brake packages will be available:
  • Mustang V6, Mustang EcoBoost: Two-piston, 43-millimeter floating calipers, 320- millimeter rotors, front; single-piston, 45-millimeter calipers, 320-millimeter rotors, rear
  • Mustang EcoBoost performance pack, Mustang GT: Four-piston, 46-millimeter fixed calipers, 352-millimeter rotors, front; single-piston, 45-millimeter calipers, 330-millimeter rotors, rear
  • Mustang GT performance pack: Six-piston, 36-millimeter Brembo™ calipers, 380-millimeter rotors, front; single-piston, 45-millimeter calipers, 330-millimeter rotors, rear
The standard brake package on Mustang GT is equivalent to the system used for the 2014 Mustang GT track package. The new GT performance package includes the same brake package found on the 662-horsepower 2014 Shelby GT500.
When maximum performance is needed
“We already set a very high standard for Mustang driving dynamics with the 2012 Mustang Boss 302, and our goal was to go above and beyond that with the performance pack on this new car,” said Pericak. “Mustang is all about performance and customization, and the available performance packs give our customers what they are looking for straight from the factory.”
The 2015 model is already the best-handling, best-braking standard Mustang ever right out of the box. Drivers looking to take their cars to even higher levels of capability can add a performance pack to Mustang EcoBoost fastback or convertible or Mustang GT fastback.
Both performance packs get:
  • Retuned springs, bushings and monotube rear dampers
  • Additional cooling capability for track-day durability
  • Thicker rear sway bar
  • K-brace connecting strut towers to bulkhead
  • Unique tuning for ABS, electronic stability control and electric power-assisted steering
  • Center gauge pack
The 2015 Mustang EcoBoost performance package also includes:
  • Front brakes: Four-piston, 46-millimeter fixed aluminum calipers with 352-millimeter rotors
  • Rear brakes: Single-piston, 45-millimeter floating iron calipers with 330-millimeter rotors
  • Unique 19x9-inch alloy wheels painted Ebony Black with Pirelli 255/40R19 Y-speed-rated tires front and rear
  • 3.55:1 final drive ratio
The 2015 Mustang GT performance package includes:
  • Front brakes: Brembo six-piston, 36-millimeter fixed aluminum calipers with 380-millimeter rotors
  • Unique 19x9-inch Ebony Black painted alloy wheels with Pirelli 255/40R19 Y-speed-rated tires, front; 19x9.5-inch alloy wheels with Pirelli 275/40R19 Y-speed-rated tires, rear
  • Strut tower brace
  • 3.73:1 final drive ratio with Torsen differential
  • Unique front splitter to channel cooling air to the front brakes
“We set out to create an all-new Mustang that would go, handle and stop better than any previous Mustang, while also being a better all-around daily driver,” said Pericak.
The results speak for themselves – during track testing, the 2015 Mustang GT with performance package consistently beat the lap times of the 2012-2013 Mustang Boss 302.
https://media.ford.com/content/ford...ford-mustang-features-all-new-suspension.html
Free Agent
2015 GT Premium
Illinois
2015 Mustang GT Prem.
I can tell I'm going to want the GT strut tower brace. :)
Brent302
Springfield VA
2015 Mustang GT/PP
Once again it's only showing Upsized rear for GT....I think only the LEs are getting the Upsized Front...
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
Love this information!! Thanks for sharing.
BOOM - The results speak for themselves – during track testing, the 2015 Mustang GT with performance package consistently beat the lap times of the 2012-2013 Mustang Boss 302.
dabears2322
Chicago, IL/ Worcester, MA
Brett
2005 Infiniti G35 coupe
Ebony painted wheels for the performance pack. Think this black is different from the "gloss black" that we have seen?
WOT
Under your bed
Gokart
Interesting, The 15 body in white is much lighter than the current car. Wonder how much lighter?
likeaboss
Baltimore, MD
2020 Corvette Z51
Who cares about the Boss. It better beat this:
DivineStrike
Doomsday
Charleston
15 GTPP, 11 F150 FX4, 07 CBR600RR
thePill
Camaro5's Most Wanted
Pittsburgh
S550
That, got its ass handed to it in SCCA T1 by a 2012 GT for two consecutive seasons... Until it dropped out of the class...
like most Camaro's, its advertised one way but actually performs another.
All the technologies they mentioned was discussed in out CD4/S550 Chassis School Thread. As I said before, the actual structure is lighter than the S197's. A 3300-3400lbs 2011-2014 race prepped GT was easy to do. I'm hoping this Gen a 3100-3200lbs GT is just as easy.
DivineStrike
Doomsday
Charleston
This is actually a very good point in relation to those interested in racing the stang. The stock curb weights will probably wind up being pretty accurate to what people will weigh them in at. But stripped down?...i will be very curious to see how much of a difference we will actually see.
oh yea and just remembered good point on the 1le as well. Keep forgetting about those ridiculous stock tires it has to help it around stock vs stock comparo tests
Todd15Fastback
Atlanta, GA
Todd
This! Someone should do a test with the same brand of tire, using each cars stock factory size and see the #'s.
That would be an interesting outcome...
DivineStrike
Doomsday
Charleston
That's still a problem as the 1le still has much bigger tires. I think they were 285's all the way around vs the track packs 255 (i think) the the Boss' 255/275. Big tires up front are important for lap times :)
Daddy Rolling Stone
Tobaccostan
2014 Mustang convertible
But, but, but, but, but ...
I thought everybody was canceling their orders because the GT only makes 435 horsepower? :doh:
danielc
photographer
ontario canada
www.danielcarusophotography.com
daniel
2015 race red gt pp recaro
^HA! My Dad got the 1LE this year, and it is fast! The open exhaust Chevrolet offers for the car with quad tips sounds good too; too bad Ford has no exhaust options from the factory. Anyway, when my GT PP arrives, I will definitely be egging him on to beat me and see who is best =].
These findings from Ford are exciting, I know many consumers over in the HP thread aren't too happy, but I am!
souprmage
Portland, OR
2015 Mustang GT w/PP 50th Appearance
The picture in the OP clearly has the PP wheels, but that doesn't look gloss black to me. Looks more satin. Things that make you go hmmmmmmm...
