New OASIS message for Engine Rattle
R1Jester
Chicago
www.r1jester.com
Tom
2016 GT350
OASIS 2888-
Some 2016 GT350 Mustangs might exhibit Piston Rattle from Idle to 3000 RPM
Some 2016 Mustang GT350 equipped with the 5.2L engine may exhibit a rattle or rapping type sound during cold operation at light loads and speeds from idle-3000 rpm. The noise will be most noticeable during light acceleration in the 1500-3000 RPM range and may also be noticeable in the 800-1200 RPM range with neutral throttle blips. This sound is caused by the piston motion in the cylinder bore. This is an inherent characteristic of the forged aluminum pistons utilized in this high performance engine. Once the engine reaches operating temperature the noise will diminish, although it may still be noticeable even when fully warm. There are no durability concerns with this sound.
Glenn G
Kaiserslautern, Germany
Glenn
15 DIB 6MT base Ecoboost
So piston slap on a fresh factory engine. Only used to be a sign of an engine bored too much for the pistons in it. But guess it's normal now.
cloud9
Sioux Falls, SD
2019 Mustang Bullitt
The Boss engine was the same way and mine was bullet proof for five years of heavy track use. Voodoo is a little more noticeable, and they probably had enough owners bring them in with concerns to issue this bulletin.
Sandoval
Western slope CO
2011 ford raptor 2016 Subaru wrx
All forged pistons do this. Its because forged pistons expand and contract more than the standard hypereutectic pistons. If a forged slug was fit tightly into a bore it would scar the shit out of the walls when heated.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Short piston skirts = rattle.
My '01 Bullitt had a ton of piston slap, nothing new.
stanglife
Jeff
1993 Coyote Coupe
Heard one running recently and like I previously suspected, definitely piston slap. My Boss motor will do this a little until it's warmed up as well. Let me dig up the article on it.
Here are Boss and GT350 piston/rod assemblies. Very similar as far as the short skirt:
http://www.mustang6g.com/forums/showpost.php?p=1072914&postcount=50
AMPowerJ posted this link, which explains the reasons behind somewhat intentional piston slap in modern engines:
http://www.mustang6g.com/forums/showpost.php?p=1072956&postcount=51
stanglife
Jeff
1993 Coyote Coupe
FYI - the alloy for the boss pistons grows very little at full temp and they are installed TIGHT. .0035 P/W clearance.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Another reason to not warm engine up by idling.
Once CHT hits above 120, you should start driving slowly.
Tomster
Beware of idiots
Tom
Excellent. That noise always bothered me. I felt a little better when I heard it on the car I drove at the gt350 track attack.
Glad its normal.
bdub85
MD
Bobby
2016 GT350 Track Package Shadow Black
I'm glad that they put something out.
I had a hunch that was it. Previous built engines I've had with forged internals would make a similar sound.
xt6wagon
WA
2016 GT350 base triple yellow
More than scar, know plenty of jdm sti motors that went pop because a piston sticks in the bore. They run tighter clearances than they should to prevent slap. Put on a bigger turbo than stock, run it hard and boom, piston wedging in breaking all the things. US motors run hypereutechnic pistons and so just puke Ringling every so often
HoosierDaddy
Randy
Looks like Ford took a page from the GM pickup piston slap playbook.
DrumReaper
South East
Not just that... The four engine fails have likely increased the awareness of the sound to the owners and concern is raised.
