89Trooper
- Aug 19, 2014
- Central Florida
- Tom
- 2015 Mustang GT
Unless you ordered your Mustang GT with a Performance Pack, or the 20" wheel option, your engine bay looks like this:
At first, I was perplexed as to why I only had half of a black "brace" going from the firewall to the passenger side strut tower. It turns out that it really isn't a brace at all. It is plastic and is only used to support the battery cover and the cowl.
The plastic part uses the exact same hardware as the full black brace. If you want to swap it out, you'll need to remove two nuts, four bolts, three battery cover clips (only two in the pic since I lost one), and six cowl clips:
I purchased the full black brace from the dealer, and here is the comparison between the half "brace" and the full brace:
Unfortunately it ships as seen above (no packaging) and needed to be painted:
It then slips right into place, exactly where the plastic piece was, but of course now goes to both strut towers (removing the positive battery cable makes it much easier to install):
I also purchased the stock Strut Tower Brace that comes on the Performance Pack and LE. Installing it is as easy as placing it across the strut towers, and installing the four nuts.
Here is the finished product!
Here are the part numbers that you'll need if you would also like to do this easy swap. You can order from your dealer, or Tasca has very good prices (click on the part numbers):
Full Black Brace: FR3Z-16K038-A
Strut Tower Brace: FR3Z-16A200-A
Two Additional Nuts: -W712334-S442 (it says "rotor nuts", but they are the same)
