Frankcurtis15
I'm attempting to install a WOT Box on a 2019 GT. Would anyone have a ECU pinout diagram for this year's model? I can't seem to find anything online. Any help would be appreciated.
Cool! Glad to hear itās working well for you. Can you please post the link for the 2019 instructions here? What color is the clutch switch wire that you tapped into for the install? Are you still running stock cats or LTHs with/without cats? ThanksI just installed one on my 2019 PP1 car. I hit them up directly and they sent me a more recent wire diagram. Only the color of the clutch switch wire was different from what they gave me but itās easy enough to figure out because the in coming wire to the switch is the same as the diagram. I was a little skeptical being a direct injection car and reading that a lot of the other products donāt work but the white box works awesome! Great customer service too
What was your launch rpm and how many hits did you make before the half shaft snapped?https://www.dropbox.com/s/gtyglz8zr6pk3ih/2019 WOT BOX Wiring.pdf?dl=0
Just installed the WOT box and trans brake on my 10r80. Worked perfectly, well enough to snap the drivers side axle.
Lund recommended to start at 3k. Saw about 5.5 on the boost controller before I let off the button.What was your launch rpm and how many hits did you make before the half shaft snapped?
Do you happen to have that diagram available? Dealing with the wot box install at the moment as well.I just installed one on my 2019 PP1 car. I hit them up directly and they sent me a more recent wire diagram. Only the color of the clutch switch wire was different from what they gave me but itās easy enough to figure out because the in coming wire to the switch is the same as the diagram. I was a little skeptical being a direct injection car and reading that a lot of the other products donāt work but the white box works awesome! Great customer service too
