Wot box install 2019+
Jackson1320
California
Jaxson
2015 mustang gt
you are going to break your oil pump gears or your crankshaft
NGOT8R
Adrian
2019 Bullitt
How many reported cases of broken OPGs have there been from running a Wot Box or MSD 2-Step launch controller?
I ran the MSD 2-Step on my 2013 GT for 3 years with no problem.
Rjavian1
Terry me
R’javian
2020 mustang gt
The diagram for the 2018 shows a green/violet coming out of the clutch switch. My 2019 appears to be blue with a red tracer. And like I said all the grounds must be black with a green tracer so it was easy to figure out. I did the clutch switch and the throttle position switch under the dash by my feet. The crank sensor and coil tap I did at the ECU. I believe you can do them all at the ECU if you want but I was trying not to get into too many wires in that large cluster. I have a Whipple stage two on the car with cat delete pipes and stock manifolds.
Can you send a picture of under your dash where the wires will b connected
DankS550
Easley S.C
Derrick
2019 gt mustang
? ? What color was the Crank wire ???
