Worn Inner Bushing- Steeda RR Adjustable Camber Arms
JKL1031
Jxn, Ms
15 GT PP Premium
Well it's that time again. Inner bushing of my Steeda Billet camber arms are worn and giving vertical wheel play again. Anyone else have this problem? Thinking about getting a machinist to make some AL or steel inserts a good idea?
tj@steeda
Timothy
Hello,
Can you email me with a video or a picture of what is taking place? Please send to tim @ Steeda
We would like to see what is taking place.
TJ
NGOT8R
Adrian
2019 Bullitt
@tj@steeda, will you please update this thread to let us know what the engineers at Steeda have to say about this? I have these arms on my car too and would like to know what the fix is, if it ever pops up. Thanks
NGOT8R
Adrian
2019 Bullitt
How many miles do you have on your Steeda adj. camber arms and how many times has the issue surfaced for you? Thanks
tj@steeda
Timothy
We are still awaiting feedback from the customer but I will provide the thread to our lead tech for his input.
TJ
tj@steeda
Timothy
They said there should be limited issues moving forward & should be no popping - unless the steel bushing sleeve wears ... which it can over time & is considered a wear part.
TJ
NGOT8R
Adrian
2019 Bullitt
TJ
Copy that TJ. Thanks! Would you please see if the lead tech can give us a ballpark idea, (in terms of mileage), when we end users might need to consider replacing the steel bushing sleeves as routine preventative maintenance?
JKL1031
JKL1031
Jxn, Ms
15 GT PP Premium
Sorry to kick up dust,
Email shows me requesting the delrin and the steel sleeves in Oct 2020. Mileage unknown. Its actually the delrin piece that seems to wear and am wondering on having machined from steel. The play is too minute to capture, but I can definitely feel it translating to the inner bushing.
JKL1031
JKL1031
Jxn, Ms
15 GT PP Premium
Here is a video showing the upper link translating best I could.
JKL1031
JKL1031
Jxn, Ms
15 GT PP Premium
I bought replacements and they were worse. Asked for refund and belive there was no response as I dont see anything after that. I still love them though I suppose..
joshuak1031
To: [hidden] (Support)
Nov 18, 2022, 11:30 AM
Could you process a refund since these are worse than what's already on the vehicle?
[hidden] (Steeda Autosports)
Nov 14, 2022, 10:08 AM EST
Good morning,
We have not had any issues. Once you install the bushings in the arm and install it back in the car, they should be fine
joshua lyons
Nov 14, 2022, 8:22 AM EST
This is a follow-up to your previous request #44050 "RE: Your order no. SO442768..."
You may want to review your dimensions.
Nov 7, 2022, 7:36 AM EST
Good morning,
Please email us some pictures. These are the same bushings we use in production of that part currently. I will forward them to production. These are the only bushings we have.
We look forward to hearing back from you.
joshua lyons
Nov 5, 2022, 7:25 PM EDT
Hi [hidden], I am not quite satisfied with the tolerance on two of the replacement bushings. Could you pick two more that are on the higher end?
Jpump
Arizona
Jeremy
2019 Mustang GT Premium PP1(Need For Green)
I believe I have something similar going on with my rear passenger wheel. I just had my rear passenger wheel bearing replaced and I still have play when rocking my wheel at 12 and 6. My rear driver side wheel is solid, I can't move it at all. I've had these camber arms installed for a little over 30k miles. It's been a week since I last worked on it, but it looked like the camber arm was moving slightly when I was rocking the wheel at 12 and 6.
@JKL1031 did you have a clunking noise in the rear when going over bumps or hitting potholes? I do, but I can't be sure if it's the camber arm, or possibly a damaged shock mount.
JKL1031
JKL1031
Jxn, Ms
15 GT PP Premium
Honestly I have an acceptable amount of clunking noise most s550 have lol. Ive shuffled around the bushings and used some I had machined to get the wheels good now but still have some noise.
Jpump
Arizona
Jeremy
My clunking noise is loud enough to be heard over music. You would of known right away if you had a similar noise. I'm pretty sure the bearing in my Steeda shock mount is bad. I think that's what's causing my clunk. I have OEM replacements, just not sure when I'll have time to install them.
Did the rear of your car feel loose with the worn inner bushing? Mine feels like it's loose if I steer left and right quickly.
