Will check for you as soon as I get home.Yours has a soft open too then? :doh:
Sorry for the delay, soft open on mine too.Yours has a soft open too then? :doh:
Yaaaaaaaaaaaaaay. About bloody time :cheers:.Thanks all for your help, glovebox is finally looking & functioning as it should! :clap2: There was just a little catch on the side that had not been pushed in properly when they replaced it. For those that are getting theirs replaced, make sure when you get it back that it opens as it should as well as being straight!
hi missb and others with this problem. i had the exact same gap, took it to my dealer in Auckland and they did a 5 min fix. apparently there was something that wasn't pushed in from the factory. they did NOT have to remove or replace anything. just a heads up. tomHow did you go with the dealer? My new glovebox has arrived & is being installed next week...
Would you be able to get the details of that? Mine is wonky toohi missb and others with this problem. i had the exact same gap, took it to my dealer in Auckland and they did a 5 min fix. apparently there was something that wasn't pushed in from the factory. they did NOT have to remove or replace anything. just a heads up. tom
i'll give them a call. tomWould you be able to get the details of that? Mine is wonky too
hi matt, i talked with the service department today. they told me they removed my glovebox and refit it properly. didn't take them long so must not have been a big job. tomWould you be able to get the details of that? Mine is wonky too
Took delivery of my Shadow Black EB in March 2016 - no problem with alignment of the glove box which has the slow open motion. No panel misalignments or paint issues. My car was one of the early builds and I have not had the quality build issues I have seen reported in mustang6g.com. My only problem has been the pony puddle light where the pony projected from drivers side rear view mirror morphed from a pony into an appaloosa with spots, then into a deform draught horse, then into a wombat shape. Has now been fixed under warranty and is projecting the pony sharp and clear.[/QUOTE
wonky glovebox stream
Awesome, thanks Tom. I wondered if it was something I could do, but will just take it to the dealer. Cheershi matt, i talked with the service department today. they told me they removed my glovebox and refit it properly. didn't take them long so must not have been a big job. tom
