OldPhart
- Nov 20, 2018
- Rochester, NY area
- Bruce
- ‘05 GMC P/U, ‘17 Impala, 19 Bullitt
Hi - If you are going to be storing your car for the winter months and are concerned about flat spotting your radial tires there are a couple of options. You can buy those curved devices you place under each tire that distributes the weight over a larger area(not exactly cheap) or you can simply inflate your tires to 40 lbs for free and they will be fine. I’ve done this for years with no problems. The reason I mention these options is to avoid putting your car up on blocks. God forbid, but if you have a fire good luck getting a car to safety that’s up on blocks. If you have several cars I suppose the best thing to do is install a sprinkler or fire suppression system in your barn or garage. Insurance is helpful, but some cars are irreplaceable... Bruce
