Will this offset fit ?
dani951
Manchester
Ford mustang gt 2016
Hi everyone sorry this might be a stupid question but I’m clueless when it comes to the alloys and offset but would alloys with these stats fit ? Also if they do to get them to sit flush does anyone know what size spacers I’d need ? Thank you
19X9.5" ET40 / 19X10.5" ET35 5X114 IN
The Demon
Brett
2022 Mach 1 N5809
Knowing exactly which year model and trim you have would help.
Pistol_91
Clearwater
2020 mustang GT
Depends which offsets the rims are if they will be flush or not
Pistol_91
Clearwater
2020 mustang GT
Et 35 and et 40 is just the sidewall size of the tire. Need to know offset of the rims themselves. Depending on actual tire width something like a +35 or +45 offset on the 10.5 wheel should be close to flush
2morrow
DesignR/DriveR/RiceEatR
NorCal Bay Area
Todd
'16 Mustang GTPP
et 35 and et 40 means +35mm and +40mm respectively. et -35 and -40 means -35mm and -40mm respectively.
That measurement is taken from the centerline of the wheel. a 10.5" wheel has 266.7 mm depth. Its centerline is 133.35 or 5.25" from front or rear inwards to center.
Flushness is attained by both wheel and tire. Tires are not all the same (see link below). A 305/30/19 from manufacturer A will differ from mfr B. If flusheness is desired I would not over tire the wheel and create bulge.
https://motoiq.com/how-to-properly-select-and-size-tires-for-performance/
Pistol_91
Clearwater
2020 mustang GT
I have a squared set up with 10.5 inch rims. 275/35/20 all around with +38mm offset. Everything is flush
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I think the fronts will look fine. You can fine tune with spacers.
I think the rears will poke by around 1/2".
NightmareMoon
2016 Mustang GT PP w/ Voodoo
I concur. The rear is a bit too aggressive by about 1/4 to 1/2” and the front is a little conservative.
If you were wanting to run 305 tires in the rear, that offset is about 10mm too aggressive. With a 275 tire its still a little much at the wheel but would work.
The front is a little conservative, but would be ok.
I’d rather have any of the common square 10” ET35 wheels out there than this setup. They will fit better on both ends of the car. Less suitable for a wide reaes tire but plenty for up to a 285 rear tire.
shogun32
Northern VA
Rears should be more like et45.
There's a guy here selling a set blue JDM wheels in 10.5 et35. I think they stick out way too much but some people like the look. But it is doable.
