Why higher gearing?
lex101
houston
2015 mustang gt
So for FI cars, e would want to try a 4.10 gear if possible? I'm interested in the thread but still learning.
jasonstang
Denver, CO
2017 GB GT/CS 6MT
No you don't. You wanna be in the 3.31 or even 3.15 range if automatic to get the boost going. Changing gear letting of throttle drops boost.
francisco511
Los Angeles
2015 Mustang GT PP
It's not that difficult if you have the proper tools and a lift. We had ours installed by Power By the Hour performance in just a few hours. You'll need the gears, gear install kit and the Whipple flare tool in order to properly calibrate the body control module.
Give us a call if there's anything we can help you with.
Thanks,
Jared
Can you use the Whipple calibrator (for the purpose of changing the gearing) on multiple cars?
lex101
houston
2015 mustang gt
Ok, sorry I should of clarified, I'm a manual. Still go 315? 331?
jasonstang
Denver, CO
2017 GB GT/CS 6MT
3.31 would be a good choice for boosting. I dont think you can get 3.15 because its an auto only but auto's have 4.17 first gear where manual is 3.66 so 3.31 x 3.66 = 12.11 vs 3.15 x 4.17 = 13.13.
beefcake
Bethel
2018 Ford Mustang
drive the car before spending the $$ on a gear, is my opinion, you may like it just as it is
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
When you purchase the Flare tool it's locked to your VIN number. If you wanted to use it on another car you can request a new file for a different VIN from Whipple and there will be a $100 fee for that file.
Let me know if you have any other questions.
Thanks, Jared
Jeffy_2010
Jeffy_2010
Missouri
Taylor
2015 gt 6-speed/ performance pack Oxford white
Are you running a manual or auto? What power level are you aiming for and will you be drag racing the car or is it just for the street?
Thanks, Jared
I'm a manual pp car, aiming for 750-800rwhp and will be a combo of drag strip and city. This car isn't my daily
Jeffy_2010
Jeffy_2010
Missouri
Taylor
if it was me, i would go for a circle d 3c before changing out the gear.
the car will still drive great on the street, but the converter will not only be stronger and hold the power better, it will allow the 60's to drop quite a bit.
I'm a m6 so no converter
LethalPerformance
Fl
The 3.73's are going to be real tough to get a handle on at that power range. It's just a lot of power for that short of a gear. You'll have to bang gears like crazy as well as hit 5th at the top of the track with them.
We went with the 3.31's and the gearing is much better now for the track and the car drives great on the street.
Thanks, Jared
Jeffy_2010
Jeffy_2010
Missouri
Taylor
Thanks, Jared
Can you send me the part numbers I will need to swap over to the 3.31 torsen?
LethalPerformance
Fl
2015 DIB GT
Upstate NY
2015 DIB GT PP Premium Roush Supercharged
So nothing actually has to be changed in the tune, just the body control module? Is this something the dealer should be able to change so I don't need to buy the flash module for just one time use?
jasonstang
Denver, CO
2017 GB GT/CS 6MT
It's just calibrating the speedometer.
LethalPerformance
Fl
You'll need your tune updated for the new gear ratio as well. As far as the dealer goes I don't believe they have the ability to flash your body control module to a different ratio however you're more then welcome to ask them. From personal experience it was very easy to use the device though.
