Whipple Stage 2 done, what's next???
Furore
Honolulu, HI
2015 Mustang GT Premium 6A
on an auto, i really think the halfshafts will do the job, just the reg ones, but we can def set you up with the dss rear end if you'd like one.
we have our full bmr / dss setup on our car, it's the quickest s/c s550 running the oem rear end.
1.3 60's, tons of passes, mid 8 sec ets, and we only expect to get quicker.
we did upgrade to the iron diff and wavetrac, which we keep in stock
Thanks Beef.. You recommended the OPG/Timing Sprocket, and MMR Balancer when I did my Whipple install... and I am crazy glad I did it, especially given some of the recent posts lately.
beefcake
Bethel
2018 Ford Mustang
never a bad idea at that power level
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Hi, just wondering what you think about stock 1/2 shafts in an automatic? I'll be putting my Whipple on it but I don't drag or run stickies. I'm just trying to keep the driveline as smooth as possible this time. I do have FFRP 1/2 shafts from my last car but wondering if I need them.
doodguy
Ruskin, FL
2015 Roush Stage 1 Supercharged Mustang GT
You shouldn't notice any drivability change with half shafts. I would definitely upgrade them
Furore
Honolulu, HI
Just bit the bullet on the following suspension upgrades:
BMR-SP089 Front Performance Springs
BMR-SP088 Drag Springs
Stock Front Struts
VIK-B358AM Viking Crusader Rear Shocks
BMR-CB005 Cradle Lockout Kit
BMR-TR005 Toe Rods
BMR-TCA045 Vertical Links
BMR-BK055 Lower Control Arm Bearing
Hoping to solve this wheel hop problem. That should do the trick.
lyarbrough
Wesley Chapel, FL
2016 Mustang GT PP, 2.9L Whipple S/C
Stock Front Struts
BMR-TR005 Toe Rods
Is that the Lethal package? Looks to be about the same things I got with mine, give or take, and hooking up is not really an issue now. :thumbsup:
Jmeo
You said member ;)
Massachusetts
Jaime
Stock Front Struts
BMR-TR005 Toe Rods
Don't forget to pick up either Ford Racing Knuckle bearings or Full Tilt Boogies version. :thumbsup:
Furore
Honolulu, HI
This isn't the Lethal Package. I got this directly from BMR on recommendations from their tech.
Yeah it gets installed next week. It should make a world of difference!
Jmeo
You said member ;)
Massachusetts
Jaime
Kelly @ BMR told me I wouldn't need them based on my needs.
Its the last piece of your puzzle. Your going to have the knuckles off to install the LCA bearings in my opinion you'd be crazy not to invest the $60 ish bucks and do them at the same time. Trust me they are definitely worth the investment and time, you will get a big improvement.
My guess is there may have been a misunderstanding during your conversation with Kelly because I know he knows these are worth it by themselves but especially when your gonna be right there doing everything else. If you don't do them they will be the last bushing in your rear suspension and you will have to be more concerned with "clocking" your suspension. With them changed to bushing you will not have to worry about that which is another reason to do them if you ask me.
Just trying to help :cheers:
Furore
Honolulu, HI
I wasn not doubting you. I believe you. I will look into it.
zuki_dan
North Carolina
15 Mustang GT Premium M6 TY
[MENTION=21427]Furore[/MENTION]No need to buy the knuckle bearings if you are replacing the toe rods. Take the joints out of the OEM toe rods they are the same bearings and cost you nothing.
Furore
Honolulu, HI
Alright thanks, bro.
Super Werty
AZ
2015 PP GT
Does BMR sell Lcas with all their spherical bearings already pressed in? I would do this. Send in your cores when done.
Jmeo
You said member ;)
Massachusetts
Jaime
Bingo, I forgot about this. Now its zero dollars but either way I suggest you do them. Good luck :thumbsup:
