Whipple Air Filter
Evo_Rob
Evo_Rob
Mmm... Boost...
Virginia Beach
Rob
As far as I can tell, my filter isn't touching anything. Just wish I could remove it easier.
nicktechla
Los Angeles, CA
www.nicktwaddell.com
Nick
2017 Camaro ZL1 Red Hot
I wonder why some of us have the filter touching and some don't.
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
Mine is as well, who did you guys talk to at whipple?
16MustangVet
North Dakota
2016 mustang 5.0
silicone over the ground straps for the time being until a better filter solution is available
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
Glad yours isn't touching Rob. It would be nice to have it come out easier but we can't put too small of a filter in as it would effect the correct amount of air necessary especially with the 132mm throttle body that most of us have. Better off wrestling with it once a year or whatever your timeframe is like.
Maybe our cars are narrower Nick :D Just one of those things I guess.
You can call and talk to anyone there. They will get you to the right resource.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
subbed
The green filters look slick,anyone figure out a part # yet ?
Scrolling through there list of Green filters this seems to be the closest of to the shorter filter that db252 got. https://www.greenfilterusa.com/store/2382 It's 1/4 shorter than his short filter so it may be easier to remove. The inlet is 6" and db252's from Whipple looked like it was 6 1/8 but that could be just because it wasn't mounted and not completely round at that point.
DetroitMustangs
Michigan
2016 Mustang GT Premium Performance Pack
Here is Whipples new air filter. I wouldn't consider this an easier filter to install/remove as it is only a 1/2 inch shorter and the base is the same. This filter is correcting an issue I had with the original which was rubbing against the ground wires that the tip of the filter was touching and eventually caused it to break creating an electrical havoc with my car. I would advise anyone to check theirs as it will eventually lead to the same problem IF yours is touching.
Here is pics of my ground wire that broke, the filter marks rubbing and my fix plus a shot of how close or what contact is made.
What were the symptoms when driving? Any dash lights?
