Which Dewalt cordless ratchet?
HoosierDaddy
Randy
I'm ready to buy my first/only cordless ratchet. I'm committed to Dewalt power tools.
Down to final 3 versions (w/current Home Depot sale prices before 10% veteran discount):
DCF512B - Atomic 1/2" $219 (with a 5 Ah Powerstack battery)
DCF513B - Atomic 3/8" $179, identical to 1/2" above except for anvil size.
DCF510B - XR 3/8" & 1/2" (substitutable anvils) $239
I actually bought the Atomic 3/8", mostly because I have several Atomic line tools and figured I'd use a 3/8" more than a 1/2". But I just opened the box and there was oil all around the head. My first thought was the tool must need periodic oiling but the very detailed manual has no mention of that. So, am researching if a manufacturing defect.
The $100+ power stack battery (and uselessly redundant charger) bundled with the Atomic 1/2" would be a plus. To be honest, to keep weight to a minimum I may need to buy such a battery for the other two ratchet options. And I don't have every size 3/8 drive sockets in 1/2 drive, so may need to use an adapter or make trips to get some.
The two Atomics are basically identical other than anvil size. They are lighter than the XR and claim to have vibration dampening for the hand.
The older XR 3/8+1/2 actually has slightly more torque but is heavier. Both no doubt due to the concept of Atomic being smaller and lighter but even more reliable. A plus of the XR is the anvil can be pointed up or down offering a little more clearance if pointing up (opposite of side with controls/light/battery). Strangely (to me) it is described as having a sealed head. I wonder if the absence of that is why the Atomic I bought has oil all over the head right out of the box.
After saying all that, I'm thinking the 3/8 Atomic is probably the least desirable for having only one ratchet unless there are factors I'm overlooking.
If Atomics don't leak and I don't mind having to scrounge up individual small size 1/2" drive sockets at inconvenient times if there isn't enough room for an adapter, maybe the 1/2" Atomic is best? Is there any such thing as a 3/32" socket with 1/2" drive? Maybe the reason they don't make a combo 3/8+1/2 Atomic is a 1/2" is best 90+% of the time when the only difference between 3/8 and 1/2 is anvil size.
Do clearance issues mean people end up buying extra shallow sockets to compensate for the extra thickness of any cordless ratchet? My recollections don't include whether my personal ratchet use would be compromised by a thicker ratchet head or handle.
Thoughts? Or if you have used any of these, comments? Thanks.
whatarush
Missouri
2016 Ford Mustang
After doing a ton of research and watching test videos on youtube, I want with the DCF510B. As for using it in tight areas. You can get a Tite-Reach extension wrench
HoosierDaddy
HoosierDaddy
Randy
Thanks a lot!
And I didn't know about the extension adapters. Makes choice easier.
Out of curiosity, did you research after the Atomic ratchets were on the market?
robvas
MI
2011 GT
Have you seen the Milwaukee insider?
a little oil on the head is normal.
can't see buying a 1/2" ratchet for automotive work
whatarush
Missouri
2016 Ford Mustang
Thanks a lot!
I did. I liked the slightly longer head and the reverse/forward switch is easier to use over the Atomic.
HoosierDaddy
HoosierDaddy
Randy
Ordering now. Thanks again!
HoosierDaddy
HoosierDaddy
Randy
Too invested in Dewalt, so best to NOT look at alternatives. As they say: what you don't know can't hurt tempt you.
1/2 inch didn't seem logical to me at first which is why I bought a 3/8 Atomic. But since at least with Dewalt Atomic, the 3/8 and 1/2 are identical size, shape and weight makes sense for a model that is both with just a toolless anvil swap. So, coin toss for me between Atomic 3/8 and XR convertible. If the sealed head convertible doesn't weep oil collecting dirt and making me wonder when it might run out is tie breaker. LoL.
whatarush
Missouri
2016 Ford Mustang
i’ve had this 510 for a little over 18 months and use it daily. It has not leak to drop of oil..
HoosierDaddy
HoosierDaddy
Randy
What spooked me a little is the manual and support do not mention anything about replacing escaped oil from the Atomic. Now maybe mine has a problem but support didn't help their cause by saying some amount of seepage is normal yet had no answer for how it would eventually leave not enough.
robvas
MI
2011 GT
Not sure why you're making such a big deal about the oil
Open it up and put a drop back in there if it helps you sleep at night
HoosierDaddy
HoosierDaddy
Randy
Not sure why you care. Hope you don't miss sleep over it.
If you've seen someone miss any sleep, you've been peeking in windows at the wrong address. :wink:
