shelbystang
What's the difference between these spark plug wire sets below?
What is the original spark plug wire size on a 1988 Mustang GT?
Between the spark plug wires sets below which one is most preferred? Taylor, Spiro Pro 8 mm wires by Taylor, Ford Racing Performance Parts, Motorcraft, or LiveWire Spark Plug Wires by Performance Distributors?
Keep in mind this is for a factory stock 1988 Mustang GT.
1984-1995 Ford Mustang 5.0L Spark Plug Wires (EFI) - by Motorcraft
#WR-4017C
Genuine Motorcraft replacement spark plug wires work great for stock applications. Great for restorations requiring factory parts! Near-original appearance with the grey-colored wires! Enjoy a fresh set of Motorcraft wires on your 1984-95 F... Read More
Relevance: 4.615166
$44.99
1986-1995 Ford Mustang 5.0 5.8 Livewires Spark Plug Wire Set Red - by Performance Distributors
space Age, Heat Resistant Sleeving Provides Protection from Exhaust Heat Custom Fit - No Assembly Required Numbered on Each End for Correct Cylinder Durable Silicone Jacket and Insulation Spiral Wound Core Prevents Electronic Interf... [URL="http://www.latemodelrestoration.com/item/PDI-C9057RD/1986-95-Mustang-50L-58L-Red-Livewires-Spark-Plug-Wire-Set"]Read More
[/URL] Relevance: 4.639391
$109.99
#WR-4017C
Relevance: 4.615166
$44.99
- 1979-1995 Ford Mustang 5.0L 5.8L Ford Racing Spark Plug Wire Set Yellow - by Ford Racing Performance Parts
#M12259Y301
VIDEO AVAILABLE
Wire-wound Custom Ignition Wire Sets feature low resistance for minimum spark loss. Silicone insulation and boots withstand high temperatures and voltage loss for minimum cross-fire and are highly resistant to fuels, oils and solvents. Long... Read More
Relevance: 3.820062
$44.99
- 1986-1993 Ford Mustang 5.0 5.8 High Energy Spark Plug Wires Blue - by Taylor
#TAY-64658
VIDEO AVAILABLE
A VALUE PRICED 8mm HI-ENERGY PERFORMANCE WIRE THAT OUTPERFORMS THE COMPETITION! Taylor’s 8mm Hi-Energy Series is a High Temperature and Oil Resistant Ignition Wire. High Temperature Blue 100% Silicone Boot Ends with double spring lockin... Read More
Relevance: 2.881612
$34.99
- 1986-1993 Ford Mustang 5.0 5.8 Spiro-Pro 8mm Spark Plug Wires Red - by Taylor#TAY-74258
- Spiro-Pro 8mm wire is the top choice of racers & enthusiasts due to its affordable value & overall high performance features. Spiro-Pro's 2 layer 100% silicone inner core & outer jacket keeps the wires flexible for the life of your vehicle ... [URL="http://www.latemodelrestoration.com/item/TAY-74258/1986-93-Mustang-50L-58L-Red-Spiro-Pro-8Mm-Plug-Wires"]Read More
[/URL] Relevance: 2.333334
$54.99
$109.99
