Where to ground fuel pumps
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Where is everyone grounding all the wiring for dual and triple fuel pumps?
z06psi
Evans, GA.
Andrew
The pot stirrer
I am going to grind the paint off and make my own for the Fore and the amplifiers. Using a ground stud.
z06psi
Evans, GA.
Andrew
The pot stirrer
I would think the seatbelt bolt would be a good one.
AS long as there is no coating between the ground wire and the body connection point.
MikeyPee
dissmember
Commiefornia
2015 IS Premium GT w/PP
I did this, after having issues with the FPDM ground
wildcatgoal
@sirboom_photography
TBD
Highly suggest you ground something like that to a welded on stud. Please.
Seat belt bolt grounds are often a fail for even car audio systems.
MikeyPee
dissmember
Commiefornia
What issues did you have?
Car died on me at Starbucks; traced it to a bad ground contact. There isn’t enough surface area, IMO, by the FPDM for a reliable ground there
kcc0521
Falls Church VA
Bo
2015 Black GT PP
Where did you end up moving the ground to?
lxh89
Dallas, TX
2015 Ruby Red Mustang GT - Whipple Auto
When it comes to fuel pumps, either find a factory ground nearby or worst case, run a heavy gauge cable straight to the negative on the battery. Getting left stranded on the side of the road is never fun...
Tony
