When should I get alignment checked/changed?
clevernickname
BC, Canada
2015 Magnetic Mustang GT, 2016 camaro ss (gfs), 2015 range rover sport, 2013 ford explorer, 2017 WRX
Or is this something the dealer will let me know about.
Stock suspension...just changing my 18s to 20s.
Banjo
Jacksonville, FL
Bill
2015 Ecoboost PP manual
I think the old wisdom was to do it every time you get a new set of tires. I normally don't though unless I do suspension work. It is probably not necessary but wouldn't hurt while changing wheels. That ~$65 could save you $100s in tires.
VinnAY
Kansas City
18 Camaro 1SS/1LE
Most places will check alignment for free and only charge if its out of spec. used to be to that you'd find a $40 charge to check it and another $40 if it's out spec. In my area anyway.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Checking your alignment when you get new tires sound like about the right interval for most people.
If you're having handling issues or notice poor tire wear patterns developing, then sure, check it more often.
Just had mine checked (installing new race rubber) and after only 1 year, my front toe had drifted in. Everything else was unchanged.
NightmareMoon
Also, I always have the alignment done by a trusted shop on any new or used car I take ownership of. Factory tolerances are far too loose for me.
jbailer
Joe
I would say whenever you mess it up. Meaning if you take it over very rough roads often, you might want to get it checked if you see uneven tire wear. Or if you lower the car or do any work on the suspension that involves loosening things that will need to be re-adjusted. I know whenever I take my car to the dealer, they always throw that little quick checker on there and tell me my alignment is out and want me to pay to have it done. Mine isn't out of alignment, it's not adjusted the way Ford recommends it stock.
