Wheel fitment
rocky5oh_eu
Unknown
Nabeel
EU 2019 Mustang GT PP1
2019 PP1
Stock suspensions
W/o magneride
To my knowledge, the factory fitment for the PP1 is 19x9 +45 255/40 front and 19x9.5 +52 275/40 rear.
I'm planning on getting the Vossen HF5s, possibly 19x9 up front and 19x10.5 on the rear. I haven't figured out the correct offsets to get as close to flush as possible but I have seen seen people running 25mm spacers all around on stock setup and are flush, so I integrated that into my calculations.
This brings me to 19x9 +20 & 19x10.5 +40. Is this correct? Also, I do plan on lowering the car just enough to have it sit flush whilst not compromising the alignment.
Are there anything else I should put into consideration?
Thanks in advance. I'm still learning 😁
Discount Tire
Arizona
discountti.re
All Things FORD
It may not hurt to do some measuring. The front lip of the 19x9 ET+20 s going to sit 1-inch further out towards the fender compared to stock. The front lip of the 19x10.5 ET+40 is also going to sit 1-inch further out towards the fender compared to stock.
MidwayJ
Dallas, Texas
Jay
2019 Mustang GT Coupe
2019 PP1
Stock suspensions
W/o magneride
You're on the right track but I would think of a 20mm spacer as the benchmark on the stock rear PP1 wheel instead of 25mm. The 25mm gives a little poke in the rear. That would get you to +45 for the rear rather than +40.
The tool at the link posted above is great. It takes tire width into account. You didn't mention the tire size planned for your 19x10.5 wheels.
rocky5oh_eu
Unknown
Nabeel
You're right, it will poke out a little. I guess a +45 is the safer option here and gives me room for spacers if I ever need them.
I was planning to run 305/30s on them.
AvalancheSVT
houston, tx
Douglas
2022 Mustang GT PP1 6spd
I just measured this and its 23mm from current PP1 wheel to the INSIDE of the fender lip.
i did this with a plumb bob from the inside of the fender measuring directly out from the tire.
i'm planning on running 19x10 +35 with 285/35/19's all the way around for this reason... but im at least 2 years out from doing that.
