Wheel Fitment
Classicnige
North Carolina
2019 Mustang gt
So im looking at buying rims and the guys said a 19x9.5 with a 25 offset in the front and a 19x10.5 with a 45 offset will fit does having a 25 offset in the front seem a little weird?i was think of maybe a 33-35 but i could be wrong anyone have any experience with having a 25 offset?im wanting 285 int the front and 305 in the back!
Jackson1320
California
Jaxson
2015 mustang gt
i have 20x10 in front with 40mm offset
and 20x10.5 rear 45mm offset with 305 35 20 front 315 35 20 rear. no spacers
Arknsawchuck
Cabot, Arkansas
Chuck
2019 Mustang GT PP2
Being its a 9.5" wide wheel +22 shouldn't be that bad. My PP2 came factory with 10.5" +24 up front and 11" +48 in the back. My track front wheels are 10" with +35.
Discount Tire
Arizona
discountti.re
All Things FORD
9.5 with +22 offset is a touch aggressive. The front lip of the wheel is probably going to sit outside of the fender by just over 1/4"
RacingRoger
NE Indiana
Douglas
Lincoln MKZ, F-150 Lariat, 2022 Mustang GT Premium
Can someone explain the range of offsets for 19X9, 9.5, 10, and 10.5 in wide wheels? For instance, my notes tell me a 19X9.5 wheel with 53mm offset works with the front. OP states a 25mm offset will work on the front.
Is there a chart out there with a range of offsets that will work on the front without spacers, yet not rub on anything and can be aligned without having to do Camber plates?
Discount Tire
Arizona
discountti.re
All Things FORD
sorry i missed typed i meant 25 offset
The front lip will be nearly flush then, will likely poke by 1/16".
Really depends the suspension and desired tire size, but the general consensus is that you can run a 9.5-inch wide wheel on the front with an offset between +25 to +40mm.
