What RPM would you shift based on this dyno graph ?
cbrtrx
tampa fl
2016 mustang gt
Looking at the graph posted and assuming the vehicle is mechanically sound to shift that high I'd definitely be shifting it at 8k. That would produce the best acceleration, anything much less would be far from optimal. Actually the 1 to 2 and 2 to 3 could even shift close to 8200.
Unas2k5
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
The RPM gauge on my car goes to 8000 RPMS IDK if there’s passing that lol
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Oh it goes far past 8000. It just doesn't show you it is......
illtal
You need to hook up the Ngauge to know where you are shifting. My nominal RPM is 8500, but the car is capable of 9000 RPM. I'd like a can monitor to be able to not have a dumb ass ngauge stuck to my window but....
Unas2k5
Unas2k5
Detroit
Samer
When does the procharger start making boost? What RPM? Like 2,300 RPM? Does that mean anytime it hits 2300 RPM even in first gear it makes boost?
I thought that prochargers just make boost at upper RPM and at lower RPMs it just sits there
illtal
No centris can make boost at other than higher rpms. Since the speed of the blower is directly proportional crankshaft speed like any other blower is done.
It still has to be turned to make boost at any engine speed.
If you see 1 lb of boost at 3k RPM your making boost
Unas2k5
Unas2k5
Detroit
Samer
Thanks for your input
I don’t have a boost gauge. I thought the graph about was showing that it was making boost starting at 2300
Cory S
Bradford, NH
Cory
It actually starts as soon as the throttle slams open above idle. It's just not very measurable.
Unas2k5
Unas2k5
Detroit
Samer
So if im just casually cruising not slamming the throttle will it make boost then ?
Unas2k5
Unas2k5
Detroit
Samer
Sir , you may have retardation.
Maybe your mom does? I’m trying to learn how this works and that has no effect on you…Just move along and don’t provide your input in a thread or post that bothers you
Cory S
Bradford, NH
Cory
No. Your bypass will be open under vacuum........
Unas2k5
Unas2k5
Detroit
Samer
illtal
If you're driving the car normally it should stay in vacuum even at an elevated rpm, with the throttle close you will stay in vacuum. But at those higher rpms wacking the throttle will cause an instant onset of boost.
Man you need a d1x with that cr. I'd bet that engine is capable of 1000.
Also get yourself a boost gauge!!!!!!!
I have one I can sell you, because it doesn't seem like I'm going to use it.
Unas2k5
Unas2k5
Detroit
Samer
Yeah I read that it’s rated above that. What gauge do you have ? Also I don’t track my car if I’m gonna punch it it will be 40-60 rolls on the empty freeway 🛣. I’m still trying to figure out what traction is gonna be like at this power level. It cold in michigan and has been since I got my car back from Brenspeed. To upgrade the head unit it’s 2k that’s not too bad I’ll probably need new injectors too.
What gauge do you have ? I did ask Brenspeed to install gauges and I got it back without any lol.
