What oil are you using?
What Oil are you using?
  • Total voters
    339
gmupatriot
Northern VA
2018 Mustang GT (Orange Fury), 401A, A10, 3.55
Anyone here has UOA for 2018 GT's? Thanks!
mechpro
2019 Mustang GT
Hi All!
Forgive the newbie question, but I read in the manual that ford recommends Motor Oil MotorCraft SAE 5W-20 Premium Synthetic Blend Motor Oil. Are you guys putting in full synthetic or the blend oil from Penzoil @smoke14me @gmupatriot
smoke14me
Tim
2017 Lightning Blue Base GT A6
Hi All!
I run Pennzoil platinum full synthetic not synthetic blend. Penzoil also makes the Ultra Platinum which according to them is better in extreme conditions. However, for a daily driver I see no reason for the extra expense.
gmupatriot
Northern VA
Hi All!
You can certainly run MotorCraft 5W-20 in your 2019 GT but thats not all you can use. As long its a 5W-20 API/SN rated oil and complies with Ford's standards you can use any brand of oil you wish. From personal experience, if you havent already, try to run the factory fill until 5000 miles at minimum. Then change to whatever oil brand you wish as long as its a 5W-20 or 5W-30 weight and stick with MotorCraft FL500S oil filter. Cant go wrong with this combination and your car will be happy and so will you.
whowasthat
ontario
2015 mustang GT
i use RP, and I get great results from BlackStone. i think it safe to say, if you use a quality oil, you will be fine
iBookmaster
Lewisetta, VA
Robert
2018 Ruby Red Ecoboost Premium
Mag1 Full Synthetic but, thinking about switching to Quaker State Ultimate Durability Full Synthetic because Mag1 does not have the new API SN Plus symbol.
Biggsy
MD
Warren
'17 GT PP, '10 Tundra
Sorry for the dumb question and if it was mentioned in another thread but I see PUP with SN and without. Which is the better choice ? Thanks
wilsons550
Canada
Wilson
2019 Mustang GT
So far from what I know is that the after market oils do not have the new ford WSS- M2C945-B1 specification required for the 2018 and 2019 mustangs stated in the user manual.
2morrow
DesignR/DriveR/RiceEatR
NorCal Bay Area
Todd
'16 Mustang GTPP
Red Line Oil 5w-50 for motor, MTL for the tranny and 75w-85 for the torsen. I run it hard on the track at high temps (thunder hill in the summer :sun::sun::sun:) and the car responds much better than me sometimes.
Speaking of heat, if you run in high heat, try the water wetter.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Whatever full synthetic is on sale.
sdiver68
St. Louis
18 GT PP1 10R80 Vert
My owners manual downloaded from Ford in July, 2018 for my 2018 GT states WSS-M2C945-A.
wilsons550
Canada
Wilson
2019 Mustang GT
That's what I showed the guy I spoke with from Ford Performances, he came back to me with a PDF file with the upgraded oil grade. I can send you the PDF file if you want.
sdiver68
St. Louis
Thank you. No its all good I believe it. I did re-check the online manual and it still states the old spec.
1004ron
Ron
2015 Mustang V6 , 2017 Ford Edge Sport
Mobil-1 5W20 at 5K miles with OEM filter
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
6500 miles today and I changed the oil to amsoil signature series with a wix filter. Limited seat time thus far but appears to be a little smoother, more time will tell.
