WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I vote Yes.
Won't make any difference. (Acoustic engineer)
I'll try to be brief.
Low frequencies are hard to attenuate. The wavelengths are long and require (really) large devices to be effective. High frequencies are short and easier to deal with. E.g. dynamat will attenuate the higher frequencies somewhat but not the mids or lows. It's also expensive (to me).
High frequency vibrations are smaller back and forth, but that doesn't mean they are quieter. Also the large body panels are effective transmitters of sound.
All of this is easily demonstrated by comparing noise level with rear seats up versus down.
Rubber bushings isolate road noise from transmitting through the suspension and framework into the cabin. But they also have lower cost so they are easy for the factory to justify.
I put spherical bearings in my car and hard rubber pucks at the diff points. Noise level is about the same to my ear, but I feel the road joints a little more. Hard bushings at the cradle points are not appropriate for my daily driver.
TrackMustang
SoCal
2021 Mustang GT
Give her the real thing!
Which one is that? I have a CF steering wheel and think this will be the only other piece of carbon I do, looking for the right one…
lacanteen
Louisiana: Cajun Country
George
Installed the first mod on this car, gas door cover, gained 1 HP. I still have a box of under the hood bling (chrome), strut tower brace, Steeda hood struts, Steeda jacking rails, and Steeda G track brace to install. It's just too hot!
WD Pro
United Kingdom
Lime GT
Nothing, because it’s still broken …
But I managed to accumulate some more parts for when it gets fixed :like:
Out with the Steeda supplied 10.9’s, hello 12.9’s with some stainless bush sleeves :
I already had the Steeda cradle support bushes, but after seeing them on a U.K. car and how they hold up against salt / winter, I decided to modify them a little.
I re tapped the 10-32” UNF holes to M5 through holes and cleaned up the sharp edges of the bore holes (top as supplied / bottom modified) :
The thread can now come all the way through making for easier fitment and reducing a dirt collection / corrosion point.
These things appear to be made as a set and then cut, rather than being fully interchangeable :
Prepped for anodising :
No more corrosion traps or bolt heads hidden down the bores and therefore hopefully easier to remove (if required) if the future :
All set for dropping at the anodisers (hopefully next week), but I’m still unsure of colour - either green or red … ?
Crawled under the car without lifting it and managed to get some better photos of what started this work in the first place - look at the movement of the bolt head witness mark :
The M14 bolt in a 17.x mm bore :
And the teeth marks from where the bolt got hungry before finally giving up and shearing :
Yeah thanks Ford, I wonder if they fix that design on the S650 … :facepalm:
WD :like:
Park
Mustang Ridge
Ken
2021 Mustang GT, 20 Mustang EB and 21 Bronco Sport
Were did you get the gas door cover ? And is it a cover ?
lacanteen
George
Bought it from American Muscle. It replaces the original cover. Takes less than 5 minutes to change. The only tools needed is a small screwdriver to release the original cover.
Rapid Red
Woodstock GA
Greg
Installed the pulley i made on my lathe to replace the bad whipple one. My naughty noise is gone.
Nice work, the lathe a magical tool that fixes the bolts right on, and is great for making a better copy of the almost.
Darthy Jo
Miami
2021 Mustang GT, 1986 Panther Kallista
Installed the RTR upper and lower grilles with LEDs today! Looks awesome! Next is lowering springs, but gotta buy a house first.
