What could be wrong with my car?
qwk93ta
Ohio
2018 GT PP1 M6 & 2015 Hellcat A8 (10.83 @ 127)
I have a 2016 Mustang GT Automatic with 12,000 miles. Last Saturday I went to the store and when I came out I could not start he car. I pressed the start button and it kept cranking until I hit the button again. I assumed the battery was bad, so I had my son jump it, it took about 20 mins, but I got it started.
when I got it home I put a trickle charger on it over night, but it did the same thing…when I pressed the start button the car would crank until I hit the button again. I had the battery checked and it’s good. I also tried using the battery out of my son’s mustang GT with the same result. The interesting thing is with either battery fully charged and a jump pack on the car it would start.
other than the non-start issue, all light works (not dim at all) and found no codes. Any help would be much appreciated.
thanks,
Mark
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
Starter going bad maybe? Alternator?
qwk93ta
qwk93ta
Ohio
That’s what I was thinking. Or a bad battery cable.
Torinate
Ontario
2016 GT Convertible
If it’s cranking fine and you tried 2 different batteries as well as jumped it and it turned over fine, look at a fuel issue. This isn’t a battery problem.
CorvZ061
Georgia
2022 GT
Listen carefully for the fuel pump priming, can you hear it?
keep a can of starting fluid nearby. Next time it does this, give it a little spray of starting fluid, if it starts for a second the. You know it’s a fuel issue. Could be a pump going bad and the extra voltage is giving the pump a little extra power to get it running.
qwk93ta
qwk93ta
Ohio
I can hear the fuel pump.
qwk93ta
qwk93ta
Ohio
I thought that too, but why would the car start and run fine if I put a jump box on a good battery?
313_S550
Michigan
Yousef
2020 Iconic Silver GT
What kind of battery is on your car, it should have atleast 600 cold crank amps to get the car started. You might have a battery not cranking enough amps. Especially since it starts with a jump.
qwk93ta
qwk93ta
Ohio
Motorcraft came with the car, it’s about 2 years old. The other one is an Interstate which is about a year old. I’ve got it in a heated garage right now and it won’t start without a jump box.
Virnman
San Tan Valley, AZ
Oxford White 2019 GT Premium Vert 401A A10
I had something very similar to this on my last ’19….very frustrating! After playing with it for a bit it turned out to be a faulty fuse for the fuel pump. Sounds like yours is turning on though….mine was only working intermittently.
qwk93ta
qwk93ta
Ohio
I didn’t find any blown fuses.
Mike Pfeifer
Wesley Chapel, FL
2019 Ruby Red Mustang GT A10
Perhaps the check valve for the fuel pump is faulty, allowing the pressure to bleed down after the car is off for a while. A leaking fuel injector can lead to the same condition but will usually result in a specific cylinder misfire after starting as well. Put a pressure gauge on the fuel line to check for pressure problems.
Cordero1
Kansas
Vic
2021 Mustang
I love reading threads like this one. I try to soak in as much as I can just in case I come up on any issues in the future.
Spodie5.0
Jody
2016 GT 350
I had the same issue not long ago. Turns out it was a bad fuel relay. It's one of the black squares in the fuse box. Cost about 40 bucks to get a new one at Ford.
