Wengerd Tune
Bulutt
Australia
2019 Bullitt
I have read only good things about Wengerd tunes BUT i want it to increase my low down torque for everyday driving improvement. so all you guys that have a Wengerd tune, is that what I will get? Thanks.
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
Noticeable improvement in low-end torque from just a tune? Probably nothing noticeable.
Now if you switch to e85, race gas, or do mods that allow more airflow then those + a tune will help give you more torque down low.
There just really isn't much to do on the car when stock with a tune power wise.
Bulutt
Bulutt
Australia
2019 Bullitt
Ok. Exactly what I wanted to know. Thanks
Bob Lob Law
Jeff
'22 GT 401A ESS A10
These motors just don't make down low torque without a PD blower.
jpjr501
Boca Raton, FL
Joe
2020 Mustang GT - Procharged
Even with a blower, Coyote's don't make a ton of torque. My car made close to 800HP but the torque was around 550. Now I have a Centri blower which with the 10R80 shifting at 8000rpm is nuts but say a Whipple or Roush will make around 600 torque.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
You can play games with the pedal map and DD tables but yea these don't make a lot of low end.
K4fxd
NKY
Maybe I should swap the Coyote out for an LS motor? 😂
If you have enough room MMR makes a 400 CI coyote block.
If I had the funds I'd try putting one in an S550. Or I'd find an early 60's Fairlane.....
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
22k just for:
  • Gen X Block Options - Add Billet Crankshaft
  • Gen X Block Options - Billet Timing Cover (For Tall Deck Version only)
  • Gen X Block Options - Chain Guide / Rr Cover kit w/chains for Gen X Tall Deck (PN#444812)
  • Gen X Block Options - MMR 3000 Head Studs
  • Gen X Block Options - Wet Block (water cooled)
  • Gen X Block
Probably another 30K for everything else.
I'd sooner drop in a Kaase Boss Nine w/ a Holley Terminator X system.
K4fxd
NKY
If I had the money to go all out it would be some form of a Proline hemi. At least that is what I'd be leaning toward without seriously researching it.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
I don't get the lack of torque comments. Its got plenty of torque imo, in fact its better this way I rather have traction then scream in high rpms. Either way tune with E85 will give you some of that or a whipple so you can whip your neck. :like:
K4fxd
NKY
