DrumReaper
- May 17, 2015
- South East
- 1971 429CJ Mach 1, 2012 Boss 302
Could just wait and get a GT500 w/ the proposed auto.
That's true but I do want to learn to drive a manual. Plus I'm guessing it will be at least 2-3 years before the GT500 comes out and I can get one without admCould just wait and get a GT500 w/ the proposed auto.
Good advice, thank youI would buy it, I hadn't driven a stick in 40 years and had concerns, but not now. I would suggest changing the clutch spring to the steeda with the adapter and going with the Pedal max throttle control (this will mitigate both the clutch being stiff and the throttle lag which for a beginner can lead to more stall outs,get a local car enthusiast to help teach you, put a battery tender in so in between lessons and before u are ready you don't have a dead battery. Unless you are very slow learner you will be up and running in short order and have no regrets, just a giant grin on your face.
And maybe being more paranoid than needed have someone follow you so that if you stall or have a slow start the guy behind you doesn't rear end you not knowing you are learning, extra buffer and less stress on you at the beginning!
One minor point. Some have suggested it is important to rev this engine out to properly seal the rings. When you are just learning to shift, it is sometimes a little difficult to find a gear when shifting at 7-8K (and I've driven a manual all my life). You can just rev it out and engine brake letting the rpms fall before shifting to the next gear.
