Vp octanium unleaded
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
So how do you mix the boostane in there ? You use a funnel and put some in the tank? How do you know if it mixed all the way thru the entire tank?
Unas2k5
Detroit
Samer
@Slopoke just wondering I may need to Use it I just don’t understand how it all works
Turbolag87
Toronto
My18 gt
What i do is go to ur local car parts store and but a fuel stabilizer bottle and put boostane in there. Then you can measure by the onces. On my paxton car running a 3.6 pulley, i run .2 Ounces per gallon on my 94 pump tune (just for piece of mind).
On my boostane tune (100oct) I run .5 ounces per gallon . My starting octane is 94 Petro.
My timing on pump is capped at 15deg
Timing on 100 oct is 19deg
Zrussian13
Phoenix
I Put the boostane in first then fill it with gas to help it mix. The mixing chart will tell you how much you need to achieve a certain octane level. I'd recommend adding more than what's suggested to make sure you get enough to mix well.
Unas2k5
Detroit
Samer
Thank you @Turbolag87 @Zrussian13
I also heard that you have to change your plugs often. Did it have that effect for you guys ?
Zrussian13
Phoenix
Yes the octane booster will foul your plugs quicker. I run boostane in every tank and I start to notice issues if I push the plugs past 10k miles.
Turbolag87
Toronto
My18 gt
To be honest i havent changed my plugs since i put my kit in (17k) car is going in for a fuel system, springs, gauges etc.... so while at it ill change the plugs and keep you guys posted. Car is going in in about a week. Only thing about the boostane is finding a mixing container that wont melt lol.
