Vortech Intercooler
SVO MkII
IL
2018 Ecoboost, 6sp, PP, 2017 GT Convertible
Sam, I won’t be in AZ until 2021 full time. We’re retiring in Yuma for winters and will be trailering the Stang to Chandler to run the road course. Between now and then I’ll be modding the car for optimum performance and no “looks /sounds cool” stuff. Once done with performance mods I’ll have it on the Dyno to see results.
You may already be well aware of this, but if you want to run the car on road courses (hard), you will need to upgrade the front brakes. Plenty of posts on that. Also, the stock PP suspension is "sporty" on the street, but too soft for serious track duty. Again, plenty of posts on that too. Enjoy!
Vicr
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
I'm running Eibach Sportlines, Maximum Motorsports Castor/Camber Plates and Koni Yellows (adjustables). After the IC then it's on to brakes
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
You picked the hottest city in the state. Good luck to you sir
Vicr
Vicr
Vic
We're going to be in the Northwest and traveling the country in my other Ford in the late spring until early fall. Any way we have family there.
jdK0uKwanxwkh3n_1wvREbtnDn6MAPB-M0EEGrCq3IDDuB6C4nZgx9e0NmzVdsa05FUy3Ow-rOwq0JXiw=w1419-h1064-no.jpg
e.
SVO MkII
IL
e.
Maybe you can get Robert De Niro to drive it down to FL for you, and you can "Meet The Fockers"!
StealthStang
South Africa
2016 Roush Ecoboost (NX2)
If u think the stock intercooler is sufficient then I think your doing it wrong lol. It heatsoaks after one good pull.
So ive got my Garret intercooler which is about 2x larger than the stock unit. Installed it and i have to admit i cant notice any big differences. I installed new high torque clamps and im getting peaks of 1.7 Bar ( 24PSI) so its running same as before.
I do notice the car can seem to hit peak boost a bit more often than before, and if i drive around in sport more for extended periods the car does feel like its holding power better.
So it seems Hellman109 was right its not really a big deal for street use, the stock IC seems good enough for 90% of the cases youre going to encounter on the street.
Though im very happy with my new IC, it looks great, fitted easily and has no boost drop or leaks. Still worth it.
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Maybe because I have a larger unit? IDK but I notice a huge difference after swapping out the stock one for my atm one. I cannot speak for the capabilities of the Garrett ic
  • Like
Reactions: Cxp
StealthStang
South Africa
The Garret is one of the best units available for this car on a stock turbo. They put far more R&D into it that any other company and all their data and testing is available to see or read. Considering they designed the turbo thats in the ecoboost im pretty sure they know what they are doing.
Vicr
Vicr
Vic
Vortech IC update. Since the Vortech install at WOT I am constantly getting at least 20 lbs. of boost. (The gauge is pegged) where before I was at 18 before OEM was heat soaked. After front brakes, down pipe and a custom tune I’ll. Dyno it and post the results. I’m just waiting to get closer to the end of warranty.
Vicr
Vicr
Vic
Curious if anyone is interested in buying a used Vortech intercooler? i know this is an old post but figured there's some interest here.
No pipes included and the only reason i'm selling is because i upgraded.
Thank you.
What did you “upgrade” to? The Vortech IC will support 1000hp.
NO1CARES
FALLING WATERS WV
17 GTPP 5.2 TH400
treadstone tr1245r
car made 1013whp through a mt82 and started to see creeping iats. Would’ve probably been fine but it wasn’t a really expensive upgrade for safety. Plus it’s getting turned up some more this season.
TeeLew
So Cal
Tim
Okay ive not really noticed the heatsoak, as I said I do on other cars ive had.
But i certainly believe what you guys say, as a result im going to try get a hold of an IC and try it and see if it makes a difference. A store here sells the Garret Mustang Ecoboost IC, seems like a good unit so ill try get my hands on one.
The Garrett is a good option. It's going to be one of those deals where you put it on your car and then understand what everyone is talking about. The stock intercooler cannot handle one good pull in my experience, certainly not in high ambient temps.
