Voltage fluctuation
partswiz
Ohio
2020 Escape Titanium, 2022 Edge ST, 2022 GT CS
Hi Guys,
Another question...I just want to confirm that it is normal to see voltage fluctuating between 12 or 12.5 up tp 14.5. Seems weird to me but maybe that is the norm on these newer cars...
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Hi Guys,
12.5 is steady state of the battery (really it’s 12.7 but the digital gauge isn’t exact). 14.5 is when the vehicle is operating and the alternator is charging the battery or otherwise operating under a load.
partswiz
partswiz
Ohio
Great info, thanks! Is it normal though to see it at 12.5 while I'm driving?
rjoseph1960
Akron Ohio
Bob
2021 Mustang Convertible GT
Hi,
I have a 21 Gt Vert, and I see the same thing on my car. I believe Ford is reducing the Battery's Charge rate on the battery due to High Under hood temperature. This will prevent boiling the acid, and drying out the battery. For piece of mind, I plug in Ford's Battery Tender everytime I park the car, my car will sit for a week at a time.
Bob
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
As long as your battery is holding a charge yes. If the battery is fully charged and you’re not using high load systems like AC, full radio volume, high beams, etc the BMS will reduce voltage on a 100% battery
AvalancheSVT
houston, tx
Douglas
2022 Mustang GT PP1 6spd
Hi Guys,
this is the way its been for decades. alternators have internal voltage regulators, pcm does stuff with it, heat changes things, blah blah.
there's a reason most cars don't have gauges that show details like ours :D
people worry too much.
Vlad Soare
Bucharest, Romania
Vlad
2020 Mustang GT 6MT
Sometimes. But not for a long time.
These cars use an intelligent, adaptive charging strategy, controlled by the BCM (body control module) using a battery monitoring system - the BMS.
When the battery has been fully charged for some time and you're still driving, the BCM will lower the voltage a bit, in order to avoid overcharging and overheating the battery. This should not last long. You may even see 12.0 volts for a short while. If it only happens under light throttle, and the voltage raises visibly while engine-braking, then drops again as soon as you touch the gas pedal, then it's all right, it's just the BMS doing its job.
