Vibrations normal?
iceman1
South Florida
2021 Mustang GT PP w/o active exhaust.
Good day everyone I just picked up a brand new GT performance pack. This is my first muscle car. I noticed when driving that there are quite a bit of vibrations at idle and highway speed. It is past the break in point. I feel the vibrations in the clutch pedal, shifter and in my seat. It’s not to the point where I can visibly see the car shaking at idle. When I get to highway speed I saw the passenger seat slightly shaking. I don’t know if that’s just the characteristic of the car, and if I should be worried.
iceman1
South Florida
its weird, because the general ride of the car is rather smooth, but then you do have this issue as well. Not to mention when the car is at low rpms (1500-2000) the car has this weird hesitation to it. This namely happens in higher gears 4-6. I notice the needle makes a weird jump between 1500-1750 rpms, then everything smooths out (that is another issue on its own).
iceman1
South Florida
This is my dream car, but not sure if what I’m feeling is normal.
CJJon
Port Orchard
2020 Mustang GT/CS Convertible - Race Red
Is it brand new or broken in?
If it doesn't seem right to you that is all that matters. Take it to the dealer and explain what is going on.
iceman1
South Florida
I bought it brand new and now it’s broken in.
Andrew@Lethal
West Palm Beach Florida
Andrew
Could be the clutch/pilot bearing/slave cylinder failing. Another thing that could cause vibration would be the driveshaft being dented or unbalanced. Third possibility would be unbalanced wheels or wheel bearings.
Roger Blose
Fairfield, CT
Roger
2018 Mustang GT, 1988 Mustang GT, 2009 Lincoln MKZ
I would look at the tires first especially if you have the Pirelli brand. Start with lowing the tire pressure to see if anything changes for the better. You cannot rotate them due to the stagger set up but perhaps some road force balancing might be next. After the tires, I would look at the driveline such as the driveshaft for imbalance. Back to the dealer for that work. Good luck.
KingKona
Virginia
Shlomo
2019 GT
If there are serious vibrations, and you feel it in the seat, it's coming from the back of the car.
Have you checked tires pressures? Have you hit anything? Smacked any curbs? Pot holes?
iceman1
South Florida
No I haven’t hit anything with the car. It’s just the vibration mainly felt in the shifter and pedals (clutch pedal). Idle or around 70mph. If you not really looking for it, then you might not realize. The vibration in the passenger seat you have to really look at it.
jlchoutex
Cypress,Tx
Jason
2021 Mustang GT 401A
Thats another reason to not buy the manual. 10R80 all the way!!!
geep81
Cleveland OH
2020 GT Premium
Nodster
UK
James
Vibration in the seat when driving is most likely (and hopefully) just a wheel balancing issue as people have mentioned. Get that one checked as it isnt expensive to have those done. Then see how it feels. Mine was the same. Felt it in my seat and in the steering wheel at around 70mph. If I pushed past to about 80mph it calmed down. Panicing thinking it was the drive shaft but it was just that some weights had come off. :)
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
if it s doing the same thing at idle then it not any above mentioned issue most likely . Probably normal. Have someone who knows cars well sit in it and advise you as you point it out.
Crowd Hunter
Tennessee
$hitbox
I'd take it to the dealer and let them tell you if it's normal.
