Very intermittent misfire/cam code issue - p0390/p0394
jack28baker
Georgia
Jack
2017 Mustang GT
I thought about this a minute and this is actually an error of the cam position sensor, not the phaser. It’s saying the cam positions sensor isn’t getting valid data, either rpm or position out of range or no or intermittent signal.
Is there anything i can log that would point in a certain direction?
jack28baker
Georgia
Jack
2017 Mustang GT
Just did a wiggle test on that sensors wiring, nothing at all. But i do have a theory in my head that makes sense to me at least. Since pac 1234x springs have significantly higher seat pressure (92lbs vs 67lbs from stock). Could it be possible that vct is having a hard time controlling cams during decel/idle where oil pressure is lowest and that sensor is reading it as a fault and putting them into failsafe? I am running 5w30, possibly 5w50 could help if thats the issue? Not sure why it would be so intermittent though but it makes a little sense in my head i guess.
engineermike
La
2018 GTPP A10
Yes, the things I mentioned earlier: cam position, desired position, and phaser duty cycle, but they need to be on a very fast data rate. There's no guarantee since it appears as though the errors it's looking for are instantaneous and it adds to the sum each time there's a problem, and when the sum exceeds a threshold you get the code.
engineermike
La
2018 GTPP A10
When I saw PAC springs that was my first thought, but that's not what the codes are indicating. It's not a desired vs actual mismatch. Mismatch or deviation are codes P0011, 12, 14, 15, 21, 22, 24, and 25. As I explained, your codes (specifically 0390 and 0394) are saying there's a problem with the cam position signal (angle out of range, speed out of range, or lack of signal). It's more of a plausibility check than a deviation check.
jack28baker
Georgia
Jack
2017 Mustang GT
Makes sense, tomorrow I will have my coworker look at it with his snap-on scanner which should be able to look at all that data which my logging software cannot.
jack28baker
Georgia
Jack
2017 Mustang GT
Was able to get a log in forscan of the issue happening, i did basic pid’s then pretty much everything with cam degree attached to it for as much data as possible. The log starts off idling fine at a light and as i start cruising, i can feel it misfiring and then at some point it goes into that fail safe mode. Hopefully it provides some useful data. I can always get more if you need.
engineermike
La
2018 GTPP A10
I took a look and noticed something a little odd but no smoking gun. Before the exhaust cam ever moved (0% duty cycle) the actual angle varied +/-.5 deg until it was finally commanded off of 0 at timestamp 40591. From that point on, 0% duty resulted in exactly 0 deg angle. That is suspicious to me because I would expect variation of tenths of a degree even at a duty cycle of 0. That said, both exhaust cams are doing the same. May be nothing, though. The misfires didn't start until timestamp 52591, or about 12 seconds after the strange 0 deg cam angle behavior.
If you wanted to continue down this path, I would take everything off of the log except Bank2 exhaust cam desired, actual, duty cycle, VCT2_EXH_F, rpm, and maybe Bank1 actual. That's 5-6 channels. I mentioned in posts 10 to log a minimal number of parameters because more parameters slows the data rate for the ones you really need. This fault is on the Bank2 exhaust cam, so that log has about 20 unnecessary parameters. I'm not sure about forscan, but with PCMTec and VCMScanner, reducing the parameter count along with the logging rate adjustment can get very fast data and you may be able to pick up the cam faults.
jack28baker
Georgia
Jack
2017 Mustang GT
Its definitely interesting how both exhaust cams do that now that you point it out, after work today I will definitely take a log using just those parameters.
jack28baker
Georgia
Jack
2017 Mustang GT
Heres 3 logs with the parameters you mentioned, hopefully at least one gives some insight. During this drive, the misfires got pretty bad and car almost died at one point. Every time they go into failsafe, i need to turn the car off and on to get readings to come up again.
engineermike
La
2018 GTPP A10
I just opened the 3rd one and it did the same thing. After the cams were commanded off of 0, they went to exactly 0.00 at 0% duty cycle. It's strange but could be normal. It's also odd that it never shows a fault for the cam. If you drive around at loads and speeds that never command over 0 exhaust cam timing, does it ever fault?
jack28baker
Georgia
Jack
2017 Mustang GT
I don’t believe so, for some reason load fixes the misfire. Say its misfiring at 1k rpm, i can downshift and its gone.
jack28baker
Georgia
Jack
2017 Mustang GT
Sorry misread your question, yes it will. Lower rpm cruising it will occasionally start to misfire. Id imagine they would be around 0 degrees then.
jack28baker
Georgia
Jack
2017 Mustang GT
Also completely forgot a possible important detail. After the install i drove it for a week or so completely fine, no issues. The thing is, i have a constant evap code from charcoal canister delete so i have no clue if those codes came up before the issues started. Week ish after install car started the misfiring and died at a light and thats when i checked and saw them. Car fires right back up though if it does die.
