V6 brake upgrade choices
Austin552
Long member
Kinston, N.C.
2017 Magnetic V6, 1968 White 5.0
GT Brakes what’s involved?
Other brands, choices?
Nagare
Ft Lauderdale
2017 Lightning Blue V6
These (I got that link from another thread, but the actual item description would lead me to believe these are the right ones for the GT calipers) are the rotors/pads I've seen a number of people (with GT brakes) switch to.
To get the actual calipers, I'd say go for Shelby Auctions first - they start at $100+75 shipping for the front set (example).
Another option for GT calipers/rotors would be thepartsfarm which has the fronts listed for $300 shipped usually.
Or just watch the classifieds forums.
Not sure on the what's required part just yet. But for someone that does know, if it comes with the lines attached like they seem to from the listings I linked above...is it just connecting the line and that's it? Are new lines needed? How does bleeding work?
ctandc72
VA
'19 GT 6 speed Base
If you upgrade to the GT base brakes (which are a huge upgrade over the stock V6 brakes) you'll need the calipers, the rotors and the brakes hoses which connect to the caliper and then connect to the factory hard line inside the wheel well.
Austin552
Austin552
Long member
Kinston, N.C.
Thanks guys looking into it.
dguzzi
Michigan
'16 V6 w/051A Met. Guard w/foundry wheels
Let us know, I have those 4 piston babies coming. Need to know more about the hoses required.
ctandc72
VA
'19 GT 6 speed Base
Just stock brakes hoses for a base GT that comes with the 4 piston calipers.
higdominator
Central Oklahoma
2016 GT PPP
I have a set of Brembo 6 pistons with new pads and relatively new rotors for $650 plus shipping if you have 19" wheels.
Otherwise the OEM lines will work across all the calipers. I have put Brembo's on an Eco (same front calipers as V6) using stock lines.
ctandc72
VA
'19 GT 6 speed Base
So you installed 6 piston Brembos on a 2 piston caliper car and the stock hoses worked? I know the stock hoses on my '17 V6 car (2 piston) are considerably different than the hoses I bought to go along with my GT (4 piston caliper) upgrade.
Maybe your EB had the 4 piston calipers already? These are the same calipers that come on the base GT. The base V6 has 2 piston calipers from the factory.
plc268
Central Texas
Patrick
2015 Mustang GT Premium Race Red
If you're worried about brake hoses, just buy new ones. They're $15 each. Worth it for peace of mind.
You'll also need 4 copper washers for the banjo bolts.
higdominator
Central Oklahoma
2016 GT PPP
No, my EB didn't have the performance pack which comes with the 4 piston brakes. It was a base, with 2 piston calipers - just like the base V6. The 6 piston brakes bolted right up. Like mentioned, if you are worried the hoses are stupid cheap.
ctandc72
VA
'19 GT 6 speed Base
It's not that I'm "worried". I already have the hoses and all parts for the upgrade, just waiting on time. Someone here posted that the stock 2 piston hoses worked on the 6 piston calipers. The metal formed ends are shaped differently - was just wondering.
dguzzi
Michigan
Just checked and the calipers are coming with GT lines. Thanks for a good thread!
ctandc72
VA
'19 GT 6 speed Base
Are new dust shields needed?
If you are going from base V6 brakes (2 piston) to base GT brakes (4 piston calipers) - NO. I ordered new shields for mine - like $8 each. They are identical (part # and all) to what came on my '17 V6 from the factory.
3.7
Orlando, FL
2020 Mustang GT Premium
Good to know as I’ll be completing this swap soon, thanks for the info!
