upgrade the 9 speakers Shaker without sub
Smunczen
Atl
Scott
2020 mustang gt pp2
I wonder also.
Cathul
Germany
Peter
Ford Mach-E
Should fit, but is missing some parts...
It's missing the DSR1 and an amp for the front/rear system and sound deadening/treatment material.
If you get these things additionally to the kit you're ready to rock and roll and it will sound way better than without.
StangTime
Ontario 🇨🇦
Todd
19' GT PP1 Manual
It's just a package of off-the-shelf components with a harness (they don't say what harness either). Also note the webpage says "This system gives you an additional 2 speakers over your Mustang’s stock 6-speaker configuration." That makes me think this is NOT for a 9 speaker system.
You will need to do some custom DIY mount for the amp and the sub-woofer box. These are not direct bolt-in parts as the webpage would have you believe. Just a heads up that there is additional work to install this. Also note that it appears this system is just a sub/amp kit and speaker upgrade. It will still use your factory amp and still have it's limited power output. Forscan will be needed to remove the factory EQ curve to make the most of it.
Jackismydog
Jackismydog
L'Islet,Qc Canada
Francois
Mustang GT 2016 Convertible
Me too I have a big question about the fit on 9 speakers. FYI I did the EQ and this is BY FAR my best upgrade ( no $$ btw) for this sound system
