Upgrade rear GT to 4 piston brembos
TeeLew
So Cal
Tim
The craziest part is the single piston rear/6 piston PP front setups are proven equal to the GT350R performance maybe better in some configurations. If performance metrics of the 350R are what the op is after, that may be the ticket. 100% agree the single piston rear caliper is not flattering at all but apparently very effective.
To be fair, I doubt if the standard GT brakes are any different in terms of performance, once fitted with good pads and 2022+ discs. The pad clamping forces are the same for all of Ford's Mustang brake configurations (past base Eco) A greater number of pistons will general provide better pad wear, but it doesn't massively affect stopping power.
Changing the rear caliper will be more for aesthetics than any other reason.
paulm1
Northeast PA
pau
2021 GT mustang
you can get your parts list off the expensive new kits for sale then start sourcing used, salvage, reman, etc. from that. I don't see a way to not swap axles & knuckles for the gt 350 calipers. If you really have to go that route look at wilwood or baer, you get to keep your axles & knuckles. the front is a much easier swap.
Bluemustang
2015 Mustang Base GT
The real answer is you do not need to change parts. The OP is looking for an answer that doesn't exist. There is no other "parts list". You can buy the full GT350R brake upgrade. A simple google search will pull it up. If you don't want that, too bad.
mdmayberry09
Missouri
Matthew
2021 Mustang GT
If you don't care to open that, here's the list from it for front and rear. I'll let you determine the rest for what you'd need.
TeeLew
So Cal
Tim
Does the AP stuff have a parking brake?
VictorH
South Carolina
Victor
2021 Mach 1
