Unofficial Off Topic Thread
sk47
sk47
North Eastern TN
Jeff
No, the analogy would be if an ICE gas tank size shrunk 8% by 100k miles. The EV power remains the same, just like an ICE engine makes the same power regardless of tank size. SMH
Hello; for what it may be worth after I made my post this morning it occurred to me, I may have gotten the battery deg wrong. During a rethink i came to the same idea you post. A shrinking gas tank analogy.
Amperage flow rate does not decrease until the battery is quite low. All battery powered tools and vehicles have to function this way,
Hello; I have and have had a number of battery hand tools. What you point out is the way the tools run. Good power for a while then a sudden drop. Also, a part of my rethink.
A question remains. Is mileage what degrades an EV battery or just time???
Balr14
SE Wisconsin
BMW Z4 M40i
The number and depth of charge/discharge cycles are what degrades batteries. Miles are pretty meaningless to a battery and a brushless motor will last many years.
Chinese car makers have started to use sodium-ion batteries instead of lithium-ion, in their EVs. . I believe GM is also going that route. Sodium-ion charges faster, easier and far safer. It discharges faster and fuller and isn't temperature sensitive. Obviously, much cheaper than lithium. too. This likely to have some positive effect on charge/discharge cycles, but that's above my pay grade.
HoosierDaddy
Randy
Not a surprise. You clearly have long had confirmation bias cranked up to 11.
Depends on battery technology used in the vehicle and usage patterns. If it helps think of it like ICE compression (and HP) loss over time from wear. But without the accompanying significant time, expense, risk and unavailability due to maintenance over 100k miles.
There probably doesn't exist an auto service business that hasn't scratched, dented or wrecked some customer's car working on or test driving. And there are zero that haven't done at least one of the following: used the wrong type or amount of fluid, left some wire loose, over or under tightened bolts or scuffed the seats, charged for work or parts never done, etc., etc..
I completely understand some tolerate that out of ignorance or special needs (like hauling plywood, long road trips across the Canadian tundra) or financial constraints or aesthetic reasons (like engine sounds).
I am just glad I have none of those afflictions other than keeping a Mustang GT on the side for the vroom, vroom and wrist exercise. :wink: 😄
I swear on a stack of bibles David did not just pen that after seeing recent posts in this thread.
sk47
sk47
North Eastern TN
Jeff
sk47
sk47
North Eastern TN
Jeff
Study reveals halving human population gradually could help Earth
Hello; some 51 years ago I was an advocate for Zero Population Growth (ZPG). The idea was for couples to limit their number of offspring to one each or two per couple. Did not work out of course as the human population has exploded since that time.
i guess the point of this post is to say i am skeptical the human population will be voluntarily halved over the next two hundred years. The math is very different for reducing an already large population from the math of slowing population growth as was suggested 50+ years ago.
I do not quibble with the idea that a big reduction of population can and will relieve the stress on the environment & demand for resources. I simply cannot imagine people doing something so sensible.
Among the many terms which can be used when discussing population along with the environment a good term is carrying capacity. Are we at or near the planet's capacity?
Are we already beyond the sustainable capacity already in a sense? By that I mean are we living on a rich but dwindling natural inheritance. By the time we technically gifted humans came along we had huge aquifers, lots, lots of topsoil, huge coal & petroleum reserves and huge forests. We have not quite yet depleted these inherited riches but are actively trying hard to.
Balr14
SE Wisconsin
BMW Z4 M40i
You are a huge proponent of fossil fuels. I'm surprised you would post something like this.
sk47
sk47
North Eastern TN
Jeff
Hello; i do not follow the thinking of your post. Please say more.
Balr14
SE Wisconsin
BMW Z4 M40i
Your last paragraph seems out of place, considering your previously stated views, opposing alternate energy....
"Are we already beyond the sustainable capacity already in a sense? By that I mean are we living on a rich but dwindling natural inheritance. By the time we technically gifted humans came along we had huge aquifers, lots, lots of topsoil, huge coal & petroleum reserves and huge forests. We have not quite yet depleted these inherited riches but are actively trying hard to."
sk47
sk47
North Eastern TN
Jeff
Hello; I see the point you are suggesting. While there are distinct problems with alternate energy a large reason for my dislike has to do with the attempt to force "green energy" & EV's onto us. So, there are two avenues for a distaste of some specific energy production schemes.
I do not know if you lumped all non-fossil fuel energy sources together as "alternative energy". Hydro power (dams) and nuclear both have some negative aspects but the good outweighs the bad in general. Nuclear has very dire potential downsides when something goes wrong with the containment. In addition, there is the waste storage issue which has been going on for much of my life. I am to be 79 in two weeks if I live.
Dams are less problematic. While I see the negative point of dams on salmon rivers, it is hard to deny the benefits of hydropower in a power-hungry world.
I like the idea of low orbit power generation. A, so far, idealized way of generating electricity. A satellite in low orbit deploys a long conductor (wire??) down as it orbits. The conductor moves thru earth's magnetic fields and frees up electrons. The satellite converts the electricity into tight beam microwaves or perhaps even a laser beam down to a receiver on the surface. Far-fetched notion to be sure, but then solar & wind as the main energy source is also a bit far-fetched.
But I guess you are looking at wind & solar power more than the other alternatives. Not ready for prime time yet is the main issue. They do not beat fossil fuels on at least three important fronts. COST, reliability & scope. I would enjoy a cleaner and cheaper energy production system which actually can handle the load. Wind and solar are not ready to do the job.
Perhaps the best point I can make is all the LED lights in my home. Only incandescent bulbs in appliances now. Very few compact fluorescent bulbs. A couple of 48-inch fluorescent lights in my basement still left. I replaced a 24 inch light with an LED type last week. The key factor was cost with LED's. When the cost made them a good deal I began to switch.
But a discussion about energy is a distraction from the greater issues of human overpopulation. Energy requirements are real to be sure, but not the overwhelming factor of too many people on a planet with limited resources.
Balr14
SE Wisconsin
BMW Z4 M40i
My position on renewable energies is they are the future. They may or may not be cost effective now, but they will improve if we support them. Fossil fuel is a dead end.
I believe the whole world would be better of if the population was reduced by half. But, getting there would be a disaster. The birth rate in every developed country is not adequate to sustain population growth. The US is 1.6 and dropping, other countries are as low as 1.1. It takes 2.0 to sustain population size. That would be great, except for the side effects. Fewer births means less people to support the older population.
HoosierDaddy
Randy
Fun fact: The countries with 1.1 rate are developing drugs that cause all births to be Siamese twins.
Yes, I know conjoined twins is the preferred cognomen but it just didn't sound as funny.
sk47
sk47
North Eastern TN
Jeff
Hello; interesting comment. one I have read and heard before. While we have a crisis due to overpopulation then a low birth rate somehow becomes a bad thing.
Hello; To get to a population reduced by half one of two things must happen. Either birth rates must drop a lot, or death rates must increase a lot. Avoiding catastrophic dearth rates was one of the tenants of the failed ZPG notion of decades ago.
Worldometer - real time world statistics
Hello; Just checked the above site. Human population continues to increase at a rapid pace. A net increase of over 41 million so far this year.
Balr14
SE Wisconsin
BMW Z4 M40i
There are lots of parts of the world that are not developed countries and 40m is less than .5% of the total population. That's hard to attach any significance.
sk47
sk47
North Eastern TN
Jeff
Hello; point being the population continues to have a net increase overall. this is early August, so the increase is likely to be around 60 million for a single year. I guess citing the increase as not significant is one way to look at the numbers.
Another way is in ten years that will be roughly 600 million new mouths to feed, clothe and house. In 20 years, that will be one billion two hundred million net increase. That assumes a current death rate.
sk47
sk47
North Eastern TN
Jeff
Hello; The future of population is not certain in the sense something unexpected can happen. However, if the past is a guide the human numbers will continue to increase. I get that in some places such as Japan the native birth rate is low. The birth rate in other places must be quite high since the overall human population has and continues to increase.
Back in the 1980's -90's I heard a statistic that if every person on the earth had a western lifestyle, we would require the resources of five additional planets the size of the earth. That has to mean multitudes of people do not have such a lifestyle.
What are the impacts of an extra 60,000,000 people each year. I cannot say exactly for 3rd world places but figure more dire poverty piled onto already existing poverty. In my area of KY & TN I have witnessed an effect. Areas which were mostly fields or farm land are now mostly residential. Back 17 to 20 years ago I was looking for a place to buy. Decided to be around my hometown of Middlesboro KY.
I went to many farm auctions. Land which had been farms for a few hundred years in some cases. Without exception the farm acreage was divided into tracts. Tracts of a few acres, The auctioneer would first auction off the individual tracts. Example a 100-acre farm divided into ten tracts of ten acres each. After each ten-acre tract got a final bid then a chance to bid on the farm as a whole would be put up at auction.
Thing being the bids on the ten tracts would be added up and the total would become the minimum starting bid for the entire farm. None of the auctions i attended ever resulted in someone keeping a farm as a whole. Always sold as tracts which became home sites and not farms anymore.
I live in one of those tracts for that matter. I have an older house built back in the 1970's. I drive by many such tracts whenever I leave the house. A new such dived farm just a few miles away.
