unable to change steering feel (2018)
samin62
Toronto
hey fellas, long time lurker and first time actually registering and posting!
I picked up my new 2018 GT Premium 401a last monday. Absolutely having a blast with this. Coming from an exclusive pick up daily for 5 years to this is such a new experience.
I have a problem I am trying to figure out, hopefully someone can help. I can't seem to change the steering feel in anything other than the normal driving mode. Sport+, Track, Drag, Wet/Snow will not. I get a msg saying option unavailable. So MyMode is essentially not working. The dealership couldn't answer anything while citing may be it is not supposed to change? But Ford advertises MyMode with Sport+ with comfort steering right here
any help would be appreciated, thanks!
When you manually change the steering mode using the Steering toggle switch in the bank of (4) toggles at center console stack, can you get the steering to change modes?
When toggling up on the switch you should see on your gauge cluster the steering mode pop up - from there use the toggle to flip through the steering options (selecting which one you would like to use). After it’s selected, you *should* definitely feel a noticeable difference in the feel of the steering response and performance.
If you still get the error when using the toggle switch - my guess is that the “As Built” dataset in your vehicle needs to be updated so that it IS an option as it should be for your vehicle.
The Ford Dealership can update the As Built data OR if you check out the DIY section on here, there is a sticky in that sub forum where folks discuss and help out with how DIYers can make such changes to the As Built datasets at their leisure at home.
Since your car is new and if that function is corrupt, I recommend taking it to your closest Ford Dealer Service Center and demonstrate the issue to the Service Writer ir Shop foreman. Discussing it over the phone or without demoing it so they can see the issue isn’t going to help - gotta show them in person with that type of malfunction.
samin62
Toronto
Thanks for the answer
as previously stated, toggling the steering switch in any driving mode other than normal will tell me "function not available"
I went to the dealership, they had no idea and msged ford engineering. The response came back as saying some vehicles don't have that function. Which is vague as hell. But I went through the owners manual from ford site and this bit was interesting.
Note: If your vehicle has adaptive dampers, the steering setting is optimized to work with each drive mode. Other steering settings may not be available.
I do have the magneride system. So I am out of luck then? Ugh I wish it was more clear when buying it.
DukeGaGa
Champaign, IL
2018 Mustang GT Premium PP
Something isn't right, I would suggest you check the as built data, I remember changing steering wheel modes in all the modes, but I can check it to make sure when I get off work today.
samin62
Toronto
Thank you, I would very much appreciate that.
DukeGaGa
Champaign, IL
I was wrong, you can't change steering mode when pre-defined driving modes are selected, this also includes saving a pre-defined driving mode as your "My Mode".
hawkbox
Arizona...in the heat
'18 GT Premium PP
Uhhh are you sure you can't? I sure can change the steering modes in sport and the other preset modes - they just dont bloody stay that way in sport...but then again I dont have magnaride..
DukeGaGa
Champaign, IL
yep, magneride will not be able to change
hbash
New York City
Howard
2021 Mach 1
I find this afternoon, that I can change steering mode ONLY when I am in Normal Mode. I could swear I used to be able to change the steering in other Modes. I may just be blinded by the beauty of my Ceramic Coated Velocity Blue Beast.
Matthewstorm
NC
Matthew
2021 Mustang GT Premium
I tried like heck to change steering modes. Then I realized it's only possible in Normal Mode. That's it. Kinda lame.
Bikeman315
Myrtle Beach, SC
Ira
I have ”My Mode“ set as follows:
Handling- Sport +
Steering - Normal
Exhaust -Track
So handling and steering are different.
Schwerin
Home
2019 Mustang
Handling- Sport +
Steering - Normal
Exhaust -Track
Do you have Performance Package or Magneride?
I remember hearing its the Performance Package that limits this.
Matthewstorm
NC
Matthew
Handling- Sport +
Steering - Normal
Exhaust -Track
So, how exactly did you do this?
Bikeman315
Myrtle Beach, SC
Ira
Honestly, it's been so long since I set this that I do not remember. I know you have to push the pony key on the steering wheel and go into My Mode. You pick your settings and save.
