Tyre / Tire Pressure advice Please
Mach1Yorky
Yorkshire
Antony
2020 Mustang Bullitt
Hi,
I recently had a handling pack fitted to my Mach 1 plus the Birds Nest wheels.
Please could you recommend the tyre pressure for road use?
Many thanks
Bikeman315
Myrtle Beach, SC
Ira
Hi,
Many thanks
Neither of the changes you’ve made affects starting tyre pressure. Go with what is on your door jamb, either 32 or 33 I believe. You can always play a little from there but only a pound or two either way.
ShadesOfBloo
SE Virginia
1980 Datsun 210 wagon, 1992 Nissan 240SX, 2008 Evo, 2020 Mustang GT
I don't think your new wheels and tires need any different pressure for day-to-day driving.
I can't post the link (security software at work messes with the address)
but I googled "mustang mach 1 tire pressure, manual" and found where Ford has posted the Mach 1 supplement for the owner's manual.
Page 47 shows tire pressures for track use.
Page 43 says:
After operating your vehicle at high speeds or track day driving, do the following:
• Set the tire pressure to the proper specification.
Mach1Yorky
Yorkshire
Antony
Many thanks for the reply and information :like:
TRDFurgesson
Mid Ohio
www.youtube.com
Bobby
22 Mach1 N0426, 22 Bronco Wildtrak 2dr, 92 Yota 4x
I can tell you that running 28lbs on cup 2's is not enough. This is 2 days of on track driving about 6 hours actually on track talking. My Cup 2's, R.I.P. had a lot more meat left in the centre 8 inches of the tire than the shoulders. I was running -3.0 deg camber / -.5 deg toe up front and -2.0 deg camber / +2.5 deg toe out back per Steeda (since I have an all Steeda suspension). I would start at 31 lbs if I had a chance to so it again. It also looks like my Sport 4s on a second set of HP wheels need a bit more pressure as well. (video included) Ive included what Ford recommends but it was not enough per my experience.
murick
Prague, Czech Rep.
Richard
2021 Euro Mach 1, FJG, manual
From where did you get the tire pressures? Is it a track spec? Mine (non-HP Mach 1) has 2.2 bar for all wheels printed on the door sticker.
