Turning Radius
L8APEX
Nice try NSA
'15 GT, '20 Raptor
because racecar
Bryman
Chicagoland
2015 Mustang GT
JoeDogInKC
Kansas City, MO
Joe
Triple Yellow 2015 GT Premium w/PP
Because not enough right pedal, that's why.
xlover
King of Laserball
Boston
2022 BMW M
Guy's...calm down! 2015 BMW M4 curb to curb turning radius is 40ft.
It is what it is. Stop picking it apart.
Agree 100%
This turning radius thing is a complete non issue and the radius is in line with most other sports cars of its size thst use similar width wheels
JonBMcD
Houston
2015 Mustang GT PP
I don't know what Ford has done.
I can tell you that it is common to fit steering stops to the rack on road race cars and when fitting really large front tires. You don't need much lock on a race course or autocross track. The only time I ever hit lock is in parking lots and I can work with 40 feet.
So basically the wheel cut degrees is less on race type cars, i.e. PP on the GT? I'm assuming this help prevents oversteering on the track. I know most of you don't think 40' isn't that big a deal, but it's causing me to pause a little on the PP. 40' and 37.8' is big difference to me. I definitely would like the stiffer ride feel and greater acceleration of the PP, but I don't need the upgraded brakes nor radiator. Also less mpg (no biggie) ugh...decisions! :/
Trevon
97 Hummer, 15 GT
SD, United States
Taylor
15 GT PP Recaro
I think it's good and bad. The H1 has a radius of 26ft so it'll be a big change for me...but on a track it doesn't matter, in fact it doesn't matter 99% of the time, maybe I'll have to turn around on a dead end, or parallel park, that's it. On the plus side, maybe it'll be much more difficult for the ricers to put a stupid drifting steering setup on these cars.
Trackaholic
2003 350Z, 2016 GT350, 2018 Pacifica Hybrid
It's not about oversteer on the track because you never turn that far. It's probably more about the wide front wheels and making sure the insides don't hit the suspension members when at full lock.
-T
Brent302
Springfield VA
2015 Mustang GT/PP
-T
[emoji106]
Boogeyman
San Jose
Eric
2015 DIB GT w/ PP
The large turn radius bugs me too, especially since the 2011-14s have much smaller turn radius. I will point out though that the 40' is the same as the m4
DivineStrike
Doomsday
Charleston
15 GTPP, 11 F150 FX4, 07 CBR600RR
I would have to agree with the wider front wheel thing. Although I think it might be wider due to the fatter tires in the back as well. Also is the torsen maybe a little stiffer at full lock? Probably grasping at straws with the last one, but just throwing out ideas. The Boss was almost 40 as well, just under.
Moderator
Super Moderator
Staff member
Moderator
Im not sure if this is the right sub forum, but anyone know what the turning radius for the 2015s? I know the 2014 had a very good turning radius. 33.4ft
I see that the turn radius on the new S550 is 37.8 with 18 and 19 inch wheels, which isn't great, BUT the GT with the PP is 40ft? What makes it over 2ft worse with the Performance Pack?
Merged :thumbsup:
aspensilver
East bay, CA
Brian
2006 MBenz SLK55 AMG - '97 BMW 540I - 2010 Audi S4
The M4 is also too wide as a DD sports car IMO. Part of the fun of a sports car on the street is squeezing through tight spots, flipping easy U turns, parking easily. I was really bummed when I found out the S550's width. Turning radius, tossability, parking, door dings, etc.
kulfyur
United States
2015 LE Mustang
Ok, I've seen this quite a few times. Can someone please explain this to me or link me to a explanation/tutorial on how to do this? Is it really just "cut the wheel and floor the gas pedal"? Sorry to be the noob here but I tried googling it and i only found one decent explanation and it doesn't seem to be the same thing. Help us out here guys. Please and Thank You.
oyitsagreen
Charlotte
2015 Mustang GT PP
Yeah that's pretty much exactly it. The rear will rotate while the front stays relatively planted /facing the same direction (long as you don't over do it!).
Basically instead of a semi circle u turn, youre turning the car into a pendulum. Means less space required to fully turn around.
Hope that helps !
