Thrermostate swap. Now it's leaking????
BlownGP
Houston/Baton Rouge
Steven
Pontiac, Ford, Dodge
This aint my first rodeo with a thermo swap. LOL
Changed mine yesterday and finally had time to drive it today since we got some bad weather yesterday.
But before I started it, I see it's wet around the connection and some seeping through the threads on the back side of the bolt.
Pretty sure I installed it right. Put the O-ring in first in the housing, then the thermostat.
Not sure what could be the problem. Hate having to dump the fluid again. lol
Thanks
Steven
gameovergt
Kevin
Lake Asbury, FL (Jacksonville area).
Kevin
2022 Ford Mustang GT California Special (A10)
gasket?
BlownGP
BlownGP
Houston/Baton Rouge
Steven
You mean O-ring/gasket?
I just watched this video
He said the themostat goes in the housing first then the O-ring. That could be my problem.
When I popped my hose off. The thermostat and gasket fell out at once so I couldn't tell which way they went.
RacerX661
@RacerX5.0
Phoenix
2017 Mustang GT Roush
I Just did mine last week mines also fell out. Took me a minute to figure it out but i used that same video. but yea thermostat first then O-ring
jlstro3
Muscatine, Iowa
Josh
Unfortunately I once made that same mistake. Painted my hood underneath w/ coolant, supercharger belt slipping all over the place. it was fun! lol
BlownGP
BlownGP
Houston/Baton Rouge
Steven
Oh ok. So it's thermostat then O-ring. That's my problem then.
Thanks buddy.
gameovergt
Kevin
Kevin
don't use the gasket/o-ring that came with the thermo. Reuse the Ford stock one.
Fleco17
Hollister,Fl
Josr
2017 Mustang Gt
I changed mine and installed the thermostat first then o ring. No leaks.
gameovergt
Kevin
Kevin
BlownGP
BlownGP
Houston/Baton Rouge
Steven
Well got it changed and no leaks.
Now the coolant temps went all the way to 220* before I shut the car off because I know that's way too high. This is off my Ngauge.
What the hell could be wrong now? lol
Fleco17
Hollister,Fl
Josr
2017 Mustang Gt
Since these system don't have a bleeder valve, it may still have some air in the system. Mine took 2 days to settle out and ran back to normal temp. Hope this helps.
BlownGP
BlownGP
Houston/Baton Rouge
Steven
Well, I started reading old threads here and forgot about the air bubble thing..I read people squeezed the hose a few times to get some of the air bubbles our.
Did that and started it up. Looks like it worked because it stayed around 187* idling. Have not driven it yet.
So I think I'm finally good. lol
Thanks for all the help guys.
