Thoughts on this turbo spec...
Kinjirra
I R Slow
Chapel Hill, TN
Brian
16 Ruby Red GT W/PP, 401a
So im putting together a turbo kit based on the budget thread by gimmie11's. Not knowing that much about turbo sizing I wanted too see what the thought was on this spec.
Tech Specs:
Air Inlet: 3"
Compressed Air Outlet: 2"
Bearing: Dual Ball Bearing
Turbine Housing Flange: Standard T4
Exhaust Outlet: 3" V-band Outlet
HP Rating: 500-600 HP
Cooling: Oil Cooled
Working Pressure: 25 PSI
Compressor: .60 A/R Billet Wheel
Turbine: .58 A/R
Compressor Wheel: 59/76 MM
Turbine Wheel: 68 /62.3 MM
GT 35 housing
Goal is more street driven the T67 with faster spool. Thoughts?
MX Raptor
Chicago
From point "A" to point "B"
I'm assuming this is a for a twin turbo application? Or are you trying a single turbo with the above specs?
Kinjirra
Kinjirra
I R Slow
Chapel Hill, TN
Brian
Yes this will be for twins
gimmie11s
SoCal
Murica!
I like it.. pm me the link
That thing should come on fast and hit hard in a twin application.
suprmario96
Hi3 Motorsports
Miami Lakes
2015 S550 Mustang GT/6S Oxford White
Do you have a compressor map and know how to figure out your corrected airflow? By plotting some points you can map out how efficient it will be. Let me know if you need help with the math.
