This is my FAVORITE modification so far!
High Velocity
Richmond, VA
2021 Ford Mustang GT
Alright everybody, My rear seat delete kit came in today. So it was time to do the prep work before the install. I started by taking out the old seat, did some vacuuming and wiped everything down with some rinse less wash.
After that I decided to lay down some sound deadener. I went with Amazon basics for this. It was only about 15 bucks and figured it would be better than nothing in there.
Now for the sound deadener I weighed it before I installed it. The whole pack was about 6.5 pounds but I did not use all of it. The rear seat delete is supposed to shave 30 pounds off the car and I probably added about 4 pounds back in the sound deadener. But it is definitely worth it.
After I laid down the sound deadener I decided to wrap the seat belt buckles in a layer of foam. I wrapped the foam around the buckle and zip tied it. Then taped it down to the floor with some 3m heavy duty tape. This way it will not make any noise under the seat delete.
The reason I did this instead of removing it, is because there were wires running to the buckle and if I had removed the buckle and unplugged that harness I was worried I would get a light on the dash.
So after all the prep work was done I moved on to installing the rear seat delete. I paid extra for it to be engraved and painted. But I also paid extra to have the bottom piece where you would sit carpeted.
I also paid to have the back of the panel with the logo on it carpeted. That way when you open the trunk, the whole trunk has carpet. Now I completely installed the back piece with the logo on it but have not fully installed the seat piece.
The reason for that is because you can see just how bad the gaps are on the bottom piece. So I am leaving this part loose until I come up with an idea to fill these holes. But you can still see what it looks like for the most part.
It looks amazing. You can even see it from outside the car at the driver and passenger windows and when standing at the front of the car looking through the windshield.
Now here are the gaps I am talking about.
And the view front the trunk
BlkMach10510
2023 Mach 1 10R80
Nice, welcome to the club. I had mine custom engraved from emp.
RocketGuy3
2021 Mach 1 6MT, 2025 Cayman GT4 RS, 2025 RS3
Looks good. Although to be honest, I'm surprised the rear seat delete only saves 30 lbs. I always just sort of figured it would be closer to a hundo or so.
High Velocity
High Velocity
Richmond, VA
I wish the fitment was a little bit better on the bottom piece. I am currently working on a solution for it. But yours looks nice.
High Velocity
High Velocity
Richmond, VA
Thanks! And no way it would save a 100 pounds. You have to remember the bottom seat is mainly just a big foam block covered with leather or fabric.
SBR70.3
Edmond, OK
2021 Mach 1, 2023 Explorer ST, 2019 GTI (back up track toy), 2026 Colorado ZR2
It looks great! However, I am having a hard time believing the seats really weigh over 30lbs. Did you happen to weigh them? I have the delete kit sitting in my garage but just have not been motivated to install it.
BlkMach10510
2023 Mach 1 10R80
From LMR.com "OEM Rear Seat | 30.8 lb"
RocketGuy3
Yeah I think it was a combination of thinking 1) those foam blocks weighed more, and 2) there were other beefier components with denser materials that would also come out with the back bench. TIL.
Hah. This makes me feel even sillier for thinking the seats would weigh more than 30 lbs.
High Velocity
High Velocity
Richmond, VA
I never weighed them. That is just what the description says. I did not buy this for weight savings. I bought it because I road trip quite often in my Mustang and I wanted this for a nice flat spot and more storage area.
Also when my doggy rides with me, he has a place to move around a little bit, with his seat belt on of course.
NGOT8R
Adrian
2019 Bullitt
What type of solution are you working on to fill the gaps on the front and sides?
High Velocity
High Velocity
Richmond, VA
I have ordered 3 separate things from amazon. So far only two came in. Third item arrives tomorrow. None of them are a great solution but here is a couple pictures of what I am thinking about using.
It's just set in place not mounted yet.
