Thinking about going big turbo? Spool Data.
Status
Not open for further replies.
Tune+
Tune+
St. Paul, MN
www.facebook.com
Adam
2015 Ecoboost Mustang Automatic
VargasTurboTech
Hayward, CA
Turbo everything
"No Lift Shift" You hold the pedal to the floor, and only use the clutch when shifting. If the EBM cannot do it with the Cobb, you can use a WOTbox like we do in the BMW's in uses the clutch switch input, and cut timing for a predetermined amount of time to let you shift without lifting
Tune+
Tune+
St. Paul, MN
www.facebook.com
Adam
It is build into the Cobb. You can even set the rpm resume limit per gear! Pretty awesome.
VargasTurboTech
Hayward, CA
Turbo everything
Boom! Cobb is already on it for you guys!
Ecoboosted15
Las Vegas
2018 Mustang GT Perf pack A10
Nice.. Im sure Adam will set me up soon enough with all that when he is tuning my 7163..
I wasn't aware the Cobb had that built in. I always lifted when at the track, I figured it will harm my drivetrain if I didn't lift
Tune+
Tune+
St. Paul, MN
www.facebook.com
Adam
With the build in NLS / FFS (No Lift shift, Flat Foot Shift = Same Thing) it is MUCH easier on the car.
DUNDEM
Miami
2015 Base EB PP
Do you like the current driveability of your stock turbo, but want more power up top?
If the answer was yes? What kit and/or setup? I too daily my car. Anything recommendations for someone want to run 93octane stock motor?
Sent from my iPhone 6+ using Tapatalk
Tune+
Tune+
St. Paul, MN
www.facebook.com
Adam
If you like the drivability/spool of the factory turbo, then you would want to look at the kit I am running on my car. The Full-Race 7163EFR kit, here is a link to my testing on my car.
http://www.mustang6g.com/forums/showthread.php?t=45723
If you are looking to get a turbo to fit directly in place of the factory turbo and use any current upgrades you have, the only option I would suggest would be the Vargas Stage 2.
PewterCam
Chicago Suburbs
2001 Z28 Camaro and 2015 Ecoboost Mustang
What if I went big turbo with a slower spool then put a higher stall converter in the car? How would that effect the boost? I'm guessing lspi would not as much of an issue with a looser converter in the car.
illeagle
Indianapolis, IN
2015 Mustang Ecoboost Premium/PP
I just hope the extra lag doesn't take away from the fun on the street. I'm excited to at least try it. I don't think it will be that bad though honestly.
Sent from my SM-G900V using Tapatalk
5.0yote
AKA Bananana & 3.7Cyclone
Mansfield, MA
www.youtube.com
Don
2016 Mustang Ecoboost Premium
It's not really, for the most part while am commuting I am hovering around 3k in and around town, once you are rowing the gears if you are out of boost it's on you. :)
Sent from my SAMSUNG-SM-N910A using Tapatalk
Tune+
Tune+
St. Paul, MN
www.facebook.com
Adam
The laggier turbo kits out there are still fun, there is no doubt that the anticipation adds to the fun factor. Power is power, it is fun no matter where it is made, I just like torque... NOW!
Regarding LSPI, it really isn't even an issue unless you make it an issue like I mentioned in another post "While everyone is losing their minds, I'm just over here....."
Don't drive in SEVERE LSPI prone areas and you won't ever have an issue. It is mostly due to the small turbo coming on so quick with too tall of a gear.
There is no fear of LSPI with any of the upgraded turbo's out there, regardless of the converter setup.
5.0yote
Mansfield, MA
www.youtube.com
Don
I agree I am also running 3.55s so it makes the extra rpms fun :)
stang77
New Jersey
I know the 7163 is the spool king. What rpm is the Vargas Stage 2 turbo spooling?
Tune+
Tune+
St. Paul, MN
www.facebook.com
Adam
Posted on the first page, it is the Brown line.
Status
