Sync 3 upgrade + Drive modes
Leosegura155
Eagle pass
Leonardo
2019 Mustang GT
Was wondering if anybody can help me out, I’m getting a sync 3 in about 2 weeks from a friend. But I’m trying to get the drive modes working on my 19 base 5.0. I know hextall does it but they require you to buy their kit but I already am getting the sync 3 so I don’t need the kit juts somebody to program it so they can work
ORRadtech
Atlanta, Georgia
Forscan may do it.
A Ford dealer certainty could.
Another option is one of the online sellers who program to the VIN might but you'd obviously have to have a VIN from a car that had it to begin with.
Overall Forscan is probably your best bet.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
If you have a 2019 it's just a simple line item with ForScan. With that said, you can't get them without the toggles that come with the 8 inch screen bezel.
Leosegura155
Eagle pass
Leonardo
2019 Mustang GT
Forscan may do it.
And how would I do it with Forscan? What device do I need to purchase
ORRadtech
Atlanta, Georgia
Forscan is a software program that can be used free in its simplest form. I don't know if that will work for you or if you'll need to purchase a license for a more robust program.
You will need an OBD2 dongle to connect your computer to the car.
Then you basically rewrite the program in the car to do what you want.
YouTube, Google and this forum are full of help and instructions on how to use it.
Leosegura155
Eagle pass
Leonardo
2019 Mustang GT
This is the one I purchased. Will this work ?
FORScan ELM327 OBD2 USB Adapter for Windows, Diagnostic Coding Tool with MS-CAN/HS-CAN Switch for Ford Lincoln Mazda Mercury Series Vehicles https://www.amazon.com/dp/B07MQ8GHG...abc_DX48QHJ0ENSQ6PPZPNSC?_encoding=UTF8&psc=1
demon67
Phoenix
67 Mustang Coupe / 21 GT Premium 6MT
It may work. I have the wireless (usb-less) version of this and it did not work. I went ahead and purchased the below which was suggested over at the Forscan forum. Booted right up and worked perfectly.
https://www.amazon.com/gp/product/B081VQVD3F/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Leosegura155
Eagle pass
Leonardo
2019 Mustang GT
demon67
Phoenix
Nice will be ordering this instead. Did you program the modes yourself?
The only adjustment I've made was to wipe the equalizer settings off. I need to remove the bass roll off as I plan to put in an amp and sub in the future. Not planning to tinker with anything else
Marsmonster
North Carolina
2021 GT Premium PP1
+1, This did it for me (2019 Base GT pp1)
Enable drive mode toggle (part 1)
ABS 760-02-02 xxxx 7x (GT Performance Pack)
ABS 760-02-02 xxxx 3x (GT without Performance Pack)
ABS 760-02-02 xxxx 1x (EcoBoost All, V6)
Enable drive mode toggle (part 2)
IPC 720-06-01 xxxx xxxx x8
Fix hazard toggle operation:
BCM 726-29-02 xxxx xxx0
This Thread:
https://www.mustang6g.com/forums/threads/enabling-drive-modes-2019-base-gt.129232/
Leosegura155
Eagle pass
Leonardo
2019 Mustang GT
This Thread:
I literally replied in another forum about this, thanks !! I had seen a YouTube vid where the guy changed the number under ACM? I got confused because in my laptop only came out as two of them like this
ABS
ABS
Marsmonster
North Carolina
2021 GT Premium PP1
ABS
ABS
Yeah, Just make sure your changing the "As Built" Data. This is what the sync vendor I purchased from instructed me to do. Worked Flawlessly.
If you have any questions let me know.
