Swapping out 373s to 331s???
Scott z
Cary il
Scott
2018 mustang gt manual
Recently had whipple stage 2 installed on my 2018 GT PP1. I have been hearing from some of the mustang community out there that I should switch from 373s( from factory) to 331s.. Is that something I should consider.. My car is a 6 speed manual( just fyi).. I need some input from you all?? How much does that coat to have done.. Retuning?? Etc.
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
That is a great idea. The cost will range from $500-$1000 depending on the shop. Or you can just swap out the entire housing.
You will have to use a hand tuner to correct the ratio so the speedometer is accurate
sZedely
Lake Orion, MI
Aaron
2019 Mustang GT PP1
See if someone is looking for the 373. Swap the whole housing.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
I'd trade you. I want 3.73 and have 3.31.
Anthony 05 GT
There you go. :thumbsup:
You guys even live in the same state.
BmacIL
Enginerd
Naperville, IL
Interceptor
Daily Driver
Low country South Carolina
2019 California Special A10
Why is the a good choice, were you using 2nd gear as first with Whipple for good 60 ft times.
Scott z
Scott z
Cary il
Scott
Thanks Anthony!! I figured as much but I like to try and do my homework before making a decision like this .. ✌
VooDooDaddy
SW Iowa
2016 GT Premium
Scott z
Scott z
Cary il
Scott
Are you sure about this?
actually no,, I am just seeing what some of my options are,, I don't know if I want to start messing around with this. Ya know. ?? The only thing is that with a SG R, PEOPLE have told me 373s are to tall of gearing. ?
BFord1
San Antonio, Texas
At your power level I would opt for the taller 331 gears if I was choosing.
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Tuner doesn't work on our cars, you have to use Forscan and update the BCM. Values are listed here.
Rear Axle Ratio (XXXX = ratio in hex) Enabled BCM 0726-12-01 XXXX xxxx xxxx
Rear Axle Ratio (3.15) Enabled BCM 0726-12-01 013B xxxx xxxx
Rear Axle Ratio (3.31) Enabled BCM 0726-12-01 014B xxxx xxxx
Rear Axle Ratio (3.55) Enabled BCM 0726-12-01 0163 xxxx xxxx
Rear Axle Ratio (3.73) Enabled BCM 0726-12-01 0175 xxxx xxxx
Rear Axle Ratio (4.10) Enabled BCM 0726-12-01 019A xxxx xxxx
BmacIL
Enginerd
Naperville, IL
Manual cars do not need to update the BCM via Forscan when swapping gears. Auto cars have to.
TripleB
Idaho
2015 GT Snack Pack- Whipple Stage 2
I'd like to trade someone my 3.73's for 3.31's... PM me if interested
