Swapping out 373s to 331s???
Bluelightning
Bluelightning
North of Houston, TX
Lightning Blue 2017 GT350, 2019 F-150 4x4 Ecoboost (Daily)
Tuner doesn't work on our cars, you have to use Forscan and update the BCM. Values are listed here.
Rear Axle Ratio (XXXX = ratio in hex) Enabled BCM 0726-12-01 XXXX xxxx xxxx
Rear Axle Ratio (3.15) Enabled BCM 0726-12-01 013B xxxx xxxx
Rear Axle Ratio (3.31) Enabled BCM 0726-12-01 014B xxxx xxxx
Rear Axle Ratio (3.55) Enabled BCM 0726-12-01 0163 xxxx xxxx
Rear Axle Ratio (3.73) Enabled BCM 0726-12-01 0175 xxxx xxxx
Rear Axle Ratio (4.10) Enabled BCM 0726-12-01 019A xxxx xxxx
If he's got the Whipple Tomahawk, it will do the update, no need for Forscan
Grintch
Hunstville
2015 GT PP
See if someone is looking for the 373. Swap the whole housing.
And give away your expensive Torsen diff in exchange for a cheap clutch LSD.
Given the 2018+'s taller gearing, this swap is a lot less necessary than it would have been on a '15-17 car. Just look at all the people going to even shorter 4.09 gears.
SVTSNAKE355
chicago
hothands
2014 GT500
Recently had whipple stage 2 installed on my 2018 GT PP1. I have been hearing from some of the mustang community out there that I should switch from 373s( from factory) to 331s.. Is that something I should consider.. My car is a 6 speed manual( just fyi).. I need some input from you all?? How much does that coat to have done.. Retuning?? Etc.
The 331 will help your top speed.
Nagare
Ft Lauderdale
2017 Lightning Blue V6
jake_zx2
Kona Blue 2018 GT
If anyone here wants to trade their 3:73 rear pumpkin for a 3:55, I volunteer as tribute!!
TURTL3
SoMD-DMV
2016 LB Mustang 3.7 6MT
If you want even taller gears, I have a loaded 3.15 pumpkin for sale.
