Summit BOV banjo fitting from ESS kit
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
Not sure if this is a problem or not. I'm not well versed in BOV'S
With my ESS kit I got the Summit BOV. My Two questions are about the banjo fitting
#1 The Banjo fitting shows online that it comes with Crush washers. Mine didn't. Should I have these? Or Does ESS pull these out of the kit for a reason (like the second spring) I'm pretty sure without them, I'm have a little leak.
#2 The fitting it's self has a hole in the screw/bolt Should that hole perfectly align with the hole in the in the barb fitting?
Picture for reference
Whitedevil95
Temecula, CA
J.P.
2022 Mach 1 HP
It should have crush washers. You definitely want those to seal it up.
CrackedHorn
Kansas
09 Mustang GT/CS; 15 Mustang GT
It would be useless without crush washers
SheepDog
Colorado
Dax
YOu definitely need the washers - the hole in the bolt does not need to line up with the barb, there is a channel all the way around the inner circumference of the banjo fitting
SnowFox
SnowFox
Mn
Grabber
Bloody hell.
Thanks for you info 👍
SheepDog
Colorado
Dax
Bloody hell.
Any auto parts store should have an assortment of copper or aluminum crush washers you can get that will fit
SnowFox
SnowFox
Mn
Grabber
Yeah, I just didn't wanna crawl under the car again 😭
lkeltner
KS
Lance
2017 GT PP1
I feel this. I swapped my precision BOV for a tial BOV under the car and getting the clamp to fit without having the oring fall out or pinch was a colossal pain.
SnowFox
SnowFox
Mn
Grabber
That's right you were doing your install a out the same time I was I think? Basically same set up G2 right?
How is it going? I'm loving mine so far. Even with a few vacuum leaks I had to track down.
lkeltner
KS
Lance
2017 GT PP1
I love it! So much fun! Blower whine is like a drug.
I've also had some vac leaks here and there that threw off the bov. Got that fixed, added a varex valved exhaust, and now eying an 18+ intake.
SnowFox
SnowFox
Mn
Grabber
It definitely put a smile on my face even with just the base tune.
