Stroboscope measure Blower belt slip?
Blackedoutdreams
Ben
2016 Gt/Cs
I always wonder why people don't use cogged belts. We used them in the steel mill and they had a shit ton more stress than any blower would place on them.
2 inch wide belts on 400 HP electric motors forcing 1/2 inch thick steel belts into a former then into a HF welder.
3.5 inch to 16" diameter pipe when finished.
Industry I work in uses polychain belts for driving feedrolls. They'll break if they go from having a constant tension to less tension back to being under full tension.
They work good for track cars from what I've been told. There's some people in the Lightning community that uses cogg belts however, they install a manual tensioner. Which is probably the only way to keep them intact on a street car.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Harley Davidson uses cogged drive belts without tensioners. They do not break
Blackedoutdreams
Ben
2016 Gt/Cs
Yeah, idk. I'm not engineer. Lol it might have something to do with the composition of the belt or the short span.
K4fxd
NKY
It's the design of the belt. The industrial belt is designed to break before the jam causes hundreds of thousands of dollars of damage.
The drive belt is designed to replace a chain and can take varying loads.
Blackedoutdreams
Ben
2016 Gt/Cs
Makes sense.
