- Nov 30, 2015
- Wellington Florida
- Ford
NEW: GRIPTEC SUPERCHARGER PULLEYS
Belt slip with supercharged setups is a widespread issue. You may not even be aware it's happening.
"Belt slip isn't always noticeable. Often belt slip is noticed when the system squeals, squeaks or boost falls off. Did you know that naturally the belt can slip a very small percentage even on NA vehicles, one major factor to belts wearing. Belt wrap does play a key factor in minimizing belt movement but when it comes to driving a supercharger is hard to fully eliminate with just surface contact. Systems running 3.4 upper pulleys can see as much as a 1.5 psi gain when matching size for size pulleys."
-GripTec /ZPE
-GripTec /ZPE
If you had an 03-04 Cobra (or other blower setup) a few years ago and you were in the market for a new supercharger pulley then Reichard Racing's pulleys were probably on your wish list.
Notice the grooves cut into the pulley where the belt sits
The Reichard pulleys had grooves cut into them to help "catch" the belt and eliminate belt slip. They were super popular and most of the time effective, however the edges of these grooves sometimes led to a shredded belt...
Shredder!
They've since been discontinued and Reichard has moved onto an entirely new arena of machining, which left supercharger customers with little choice in pulleys...
UNTIL NOW!
We are happy to introduce the GripTec supercharger pulley line from ZPE!
Whipple Superchargers have been using these pulleys in some of their applications with great success. Dustin Whipple recommended that we carry the line and we're impressed!
What sets these pulleys apart from any other pulley?
It's ZPE's patented GripTec technology!
Close up shot of a GripTec pulley's belt surface
ZPE uses two patented processes to increase surface grip: GripTec Micro and GripTec Weld.
GripTec Micro is a CNC ablation process which removes material from the surface of the pulley where the belt would sit.
GripTec Weld is a micro welding process in which material is added to the surface.
Both of these processes serve to increase the pulley's grip potential by increasing the friction between the pulley and belt using an engineered grip pattern, thereby eliminating slip.
To give you an idea of the grippiness (is that even a word??), JMS Chip & Performance has the option to add a GripTec finish on the inside of their Avenger & Savage series wheels. The coated edge acts similar to a beadlock by keeping the tire from spinning on the wheel.
JMS wheel with a GripTec finish
Whether you are running a 3.75" or a 2.50" pulley on your Whipple, Procharger, Vortech or other supercharger you can surely benefit from the added grip of these GripTec supercharger pulleys.
"Belt slip is a very common issue on supercharged components. In fact some units cranking out as much as 14-16 psi can take up to 200hp to drive. Often the drive systems are plagued with slippage issues and builders find themselves moving to noisy cog systems, where belts have shorter life spans, are difficult to find at just any parts store and they can create more heat through the frictional movement of the cogs."
-GripTec /ZPE
GripTec pulley on a Whipple setup
YOU COULD BE LOSING HORSEPOWER FROM BELT SLIP. DON'T LET THAT HAPPEN TO YOU.
Check out some of the pulleys here:
6-rib Whipple GripTec pulley
8-rib Whipple GripTec pulley
10-rib Whipple GripTec pulley
6-rib Procharger GripTec pulley
8-rib Procharger GripTec pulley
6-rib Vortech / Paxton GripTec pulley
8-rib Vortech / Paxton GripTec pulley
NEED ONE FOR A DIFFERENT APPLICATION? GIVE US A SHOUT!
877-2-LETHAL or [email protected]
#teamlethal
