Strange steering pull when accelerating
DIBstang
Michigan
2015 DIB GT PP
Long time lurker and very occasional poster here.... I have a 2021 GT/PP with no mods and OEM Pzero tires. Over the past couple of days the car has developed a significant pull to the left when accelerating - both from a slow roll and highway speeds. Also, it feels like the back end is shifting slightly to the right when this happens.
It has never done this before, so it obviously seems very strange. Tire pressures are ok and i dont see anything visable during a very basic look around.
Any thoughts/ideas on when might be going on?
Thanks
mookieit
tampa
john
mustang 2015 v6
How is your alignment?
Skye
≈39N
"Skye" Mach1 N2144
The tires being used now, are they the same age and mileage? Same tread depth? Any recently replaced?
DIBstang
Michigan
2015 DIB GT PP
all the same original tires with 41,000 miles. no out of the ordinary tire wear.
Skye
≈39N
"Skye" Mach1 N2144
So same tires, tread height and wear. That's good.
Tires can develop radial pulls over time. But in these examples, the sensation is often constant. In your case, it seems to only be happening on acceleration.
While the tires could be rotated front to back and vice-versa to see if anything changes or other tells present, Edit, car is PP, with standard, OEM, staggered setup.
I wonder if something with the diff is going on? Spitballing...
Mach VII
Berkshire Hills, MA
2019 Mustang GT 401A, 1989 Lincoln Mk VII LSC
I want to know how you got 41k out of a set of P-Zeros...
DIBstang
Michigan
2015 DIB GT PP
Tires can develop radial pulls over time, but in these examples, the sensation is often constant. In your case, it seems to only be happening on acceleration.
While the tires could be rotated front to back and vice-versa to see if anything changes or other tells present, I wonder if something with the diff is going on? Spitballing...
It is a PP so the tires cant go back to front, but your diff comment got me thinking again because it does feel the back end is shifting to the right or maybe some kind of uneven power application.
DIBstang
Michigan
2015 DIB GT PP
haha great point - its closer to 20. I swap out tires and rims for winter. and to your point, they are garbage tires. the backs are basically slicks at this point.
Torched10
Atlanta
Bob
I think it's the tires.i only got 15000 on my new carv and it started pulling on me.whrn you get them get them aligned
cerbomark
TN
20 GT PP2. 21 Mach1 (Sold)
tires (rotate them side to side if you can)(if they are slicks then it could just be trammling);replace
alignment;
something amiss in the rear; (axle related?)
I would do it in that order. The first two are only maintenance anyway.
RiotfunK
mass
Binx
22 mustang GT Premium PP1 Manual
Get new tires
ORRadtech
Atlanta, Georgia
That was my first thought.
My first guess was it's time for new tires. I hated the PZeros especially once worn.
Second guess was wheel bearings. But since the OP said the rears are almost slicks I'm going with tires.
