Strange...Radiator Cap Separated on Overflow Tank?
CVCashmere
South Jersey
Carl
15 GT Vert w/Steeda lower brace, PP sways & susp
I thought I would do a little preventive maintenance today and went to take off the radiator cap. So I turned the cap and eventually, the top of the cap came off...but the core remained! Any quick ideas how to remove it?
thanks
CVCashmere
Chef jpd
Brooklyn, NY
get the engine up to temperature.and it will probably blow off.
A towel on top to prevent carnage.
lawrencecar
Virginia
2017 Mustang Ecoboost PP
i saw this similar on another thread. i believe he used needle nose pliers to twist and remove
88lx50
NYC
2018 Mustang GT convertible 6 speed
When you get it out use some silicone on the o ring.
CVCashmere
CVCashmere
South Jersey
Carl
Thanks to Chef's idea, I heated it up with a hair dryer, put some PB Blaster on it to get between the O-ring and tank, and still had to cut it to pull it out.
Then, I coated the O-ring and contact points with a light layer of liquid teflon so that it would not bond to the housing.
My suggestion...open the cap periodically so that the cap does not seize.
CVCashmere
smann
Toronto
2016 GT PP
My cap seized as well and it separated from the cap.
Haha I thought I was the only one
CVCashmere
CVCashmere
South Jersey
Carl
Must be the Oxford white color that causes a transpheric amorphous reaction between the caloric exchange rate of the plastic jellyfish housing and the case-hardened plastic cap shroud.
That's my explanation...and staying with it!
CVCashmere
Chef jpd
Brooklyn, NY
Maybe it is just a Canadian curse.........
CVCashmere
CVCashmere
South Jersey
Carl
or perhaps, some New Yorker snuck under the hood when I wasn't lookin'...and superglued the cap shut???
CVCashmere
GT Pony
Pacific NW
After reading this thread I used some silicone grease on the O-ring on the coolant tank cap. I popped the O-ring off the cap to get the silicone grease coated over the entire O-ring. The cap seems to screw on and off easier now.
